Now that it gets dark so early I'm often tooling around with the toddler in the back seat after dark. I'm often wanting to turn the dome lights on to check on him - is he so quiet cause he fell asleep? What is he banging around? etc.However, I find the combo dimmer/dome light dial a pain in the (removed). It has to be dorked around with to get the lights on (all the way up is "OFF"), meanwhile the instruments get too bright, and then I have to dork with it again to get the dimmer set how I like it. So finally I got tired of it and put in a simple switch for the dome lights.(Those of you with 2006+ Vibes can be thankful they finally fixed this for you!)I got a push-on, push-off type button and put it in a blank cover plate like the one to the left of the steering wheel, next to the coin slot. A rocker or toggle switch would work just as well. The switch should make contact in the "on" position (normally open).Wires with quick disconnect lugs will connect it to the dome lights behind the dimmer dial.The trim piece containing the dimmer dial can be removed using a taped, flat tool. I used a flexible putty knife. The tape keeps it from scratching the trim or dash. Pry up around the edges to pop the trim out.---You want to connect the switch to the two circled wires below, at the connector behind the dimmer dial. The white/black wire is ground, and the red/black wire is the low side of the dome lights. Connecting the low side of the dome lights to ground will turn them on, so we want the switch to connect these two wires.I used T-Splices, which just clamp on the wires, then the lugs plug into them.---Bring the switch wires into the blank hole, and up around to connect to the T-Splices. Push the blank with the switch into place and replace the trim.All Done!! You can get T-Splices and Lugs online at http://www.mouser.com. The splices (aka taps) are Part #538-19216-0018, and the quick disconnect terminals (lugs) are part # 159-3251.
