How would one aim the Washer Nozzels? My passenger side could use a slight adjustment.And the rear needs to point more to the passenger side rather than straight down the back. (better to soak more of the blade)
Bill, for the rear you may want to upgrade to the newer style nozzle. It is a two spray pattern design and works better. I know there is a thread on it since I did it and others did too. Here it is and you were the last to reply! LOL!! http://forums.genvibe.com/zerothread?id=12385
on my old VW i used a straight pin and my wife sat in the car and activated the nozzles whenever i said "ok, try it now".(push pin into nozzle and gently adjust as if moving a joystick)
Quote, originally posted by MiVibe-ToolGuy »Bill, for the rear you may want to upgrade to the newer style nozzle. It is a two spray pattern design and works better. I know there is a thread on it since I did it and others did too. Here it is and you were the last to reply! LOL!! http://forums.genvibe.com/zerothread?id=12385Thanks MiVibe-ToolGuyI have read those long ago, I may do that sometime, but this time of year money is tight! Wanted a temp soloution. Now to find where my wife might have a straight pin!
