The Answers:1. Why should I choose Magnecor Ignition wires ? Magnecor RACE WIRES: Magnecor KV85 Competition (8.5mm) and Magnecor R-100 Racing (10mm) Ignition Cables are primarily designed for modern race and modified production vehicle engines that use computerized engine management systems and high-output ignition systems. Magnecor's exclusive Metallic Inductance EMI Suppressed 2.5mm high-capacity conductors (that cost 4 times more to manufacture than original equipment or generic ignition wire conductors) will maintain conductance of full spark energy indefinitely without emitting EMI and RFI. For heat protection, Magnecor Race Wires have insulating jackets made entirely of aerospace silicone rubber (which costs 2-3 times more than multi-layer generic jackets used on all other ignition wires) that will withstand heat better than any other ignition wires.Unmodified exhaust-emission controlled production vehicles will also benefit from the improved ignition performance and permanent EMI suppression provided by Magnecor Race Wires. Best of all, Magnecor makes wire sets for almost every engine ever made, as well as custom made sets or individual leads to suit customer's requirements.Original equipment or aftermarket carbon conductor (suppression) ignition wires and European and Japanese spiral wires will provide adequate EMI and RFI suppression during the limited service life of this style of ignition wires. However, none of these wires are designed to be used with high-output ignition systems, and will fail prematurely at conductor terminations if used on a race engine, or an engine used in a street vehicle where the original ignition system has been replaced with a high-output ignition system.Spiral conductor ignition wires that most performance parts marketers include in their product lines sold through speed shops and mass-merchandisers in the USA will function satisfactorily on a carbureted race or modified street engine — however, none will prevent EMI from interfering with a modern engine's electronic ignition and fuel management system, or any other on-board electronic device. Most "low-resistance" and "super" conductor etc. wires are nothing more than branded cheaply constructed generic spiral conductor wires containing conductors that won't provide (despite claims) either adequate EMI or RFI. More expensive versions are dressed-up in elaborate colorful sleeves to protect inferior jackets against the heat of a race motor. EMI radiated from these ignition wires can adversely affect the function of computer managed electronic ignition and fuel systems, which in turn, will decrease engine efficiency. Some of these wires have been made to resemble Magnecor Race Wires in both color and cable diameter, however the conductors and insulating jackets used are entirely different.Magnecor's Conventional Style 7mm and 8mm ELECTROSPORTS Series Ignition Cables will provide the conductance and heat resistance similar to the very best wire sets our performance parts competitors have to offer, and superior to all the rest. However, unlike our competitors' performance ignition wire sets lines, all of which cover only a very limited selection of popular unmodified and modified engines, Magnecor's 7mm and 8mm ELECTROSPORTS Ignition Cable line includes ready-to-fit wire sets for almost every engine ever made, as well as sets for popular modified engines and custom made sets or individual leads to suit the requirements of customers (and at very competitive prices). Our previous version conventional style 7 and 8mm HIGH PERFORMANCE Cables were always popular for use on older vehicles and restorations that did not require full EMI suppression. With our new ELECTROSPORTS Series, full RFI and EMI suppression is provided, allowing these cables to be used on any vehicle, no matter whether the engine is old, new or technically advanced.2. What is EMI, and why is it important to suppress it ? EMI = electromagnetic interferenceEMI from spark plug wires can cause erroneous signals to be sent to engine management systems and other on-board electronic devices used on both racing and street vehicles in the same manner as RFI (radio frequency interference) can cause unwanted signals to be heard on a radio receiver. Engine driveability problems ranging from intermittent missing to a dramatic loss of power can result when engine management computers receive signals from sensors that have been altered by EMI radiating from spark plug wires. This problem is most noticeable on modern street vehicles used for commuting where virtually every function of the vehicle's drive train is managed by a computer. For many reasons, the effect of EMI on engine management computers is never predictable and, often, improper diagnosis for a driveability problem results in huge repair costs for a consumer because engine management sensors and other parts are replaced when all that was needed was a set of ignition wires capable of suppressing EMI (usually replaced as the last resort). As production vehicles age, engine management sensors, connectors and wiring deteriorate (and corrode) and become more susceptible to EMI radiated from spark plug wires not able to adequately suppress EMI. The problem is often exacerbated by replacing the original ignition system with a high-output system.3. Some performance ignition wires advertise EMI suppression - are Magnecor Race Wires suppressed any better? Unfortunately, the claims in promotional literature and advertisements that so-called "super conductors" and "low-resistance" spiral conductor, as well as so-called "built-in capacitor" wires are EMI suppressed are as factual as other claims you see for the same wires such as: "300 times more powerful spark" — "30 times more spark energy" — "15 times more powerful" — "over 300% more spark energy" etc. In reality, it is impossible for "low-resistance" spiral conductor and so-called "built-in capacitor" wires to properly suppress EMI (or increase sparks or horsepower), even with the application of a short-lived conductive coating (in which the spark current actually travels when the wires are new) over the conductors' spiral windings (see Truth About Ignition Wire Conductors).Performance parts marketers of "low-resistance" spiral conductor wires in particular have always claimed their wires provide RFI suppression (which can be heard on a radio), but in reality, the RFI suppression provided is far from adequate. Fortunately for the marketers, in anticipation of promised additional spark energy and horsepower, most consumers who listen to FM broadcast stations and drive in areas where AM radio signals are strong will accept less RFI suppression than that provided by original equipment ignition wires. Recently, the same marketers have decided they need to claim their "low-resistance" spiral conductor wires are also EMI suppressed, and whereas consumers are able to overlook inadequate RFI suppression, the same can't be said about inadequate EMI suppression, because of its effect on the driveability of vehicles using computerized engine management systems. See our "A Brief Overview ..." document for more information.Again, fortunately for performance parts marketers, it's surprising just how few people (experts included) ever associate EMI from ignition wires with driveability problems, and since very few people ever challenge such ridiculous claims as "300 times more powerful" sparks etc. etc., the same marketers see no reason why they can't also claim their "low-resistance" and "super conductor" etc. spiral conductor and "built-in capacitor" wires are EMI suppressed — when in fact none are!Magnecor Race Wires are specifically designed and constructed to suppress EMI on high performance engines, using materials and production methods too costly for ignition wires destined for marketing through mass-merchandiser and most speed shop outlets. The EMI suppression is permanent, as no conductive coatings are used in Magnecor Race Wires. Do not be deceived by the claims m
ade for so-called "super conductor" wires sold by most speed shops in the USA which have a heavy application of a conductive coating over the spiral windings — although these wires are made to imitate Magnecor KV85 (8.5mm) ignition wires in both size and color, neither the EMI suppression nor the heat resistance is anywhere near that of Magnecor Race Wires.Magnecor Race Wires are used by race teams all over the world for the purpose of eliminating the problems caused by EMI from ignition wires interfering with on-board electronic equipment. 4. Do I need ignition wires with a low electrical resistance ? No. For a detailed answer to this important, and very frequently asked question, see: Truth About Ignition Wire Conductors.4.1 (Related answer to question 4) I have seen an MSD demonstration stand which compares all the well known "performance" wires — it shows Magnecor KV85 wire’s resistance is higher than any other brand of wire on the stand !The MSD demonstration stand (which MSD places in many speed shops and performance parts retailers) is designed to demonstrate that a MSD wire has a lower resistance than any other brand "performance wire." The issue of low resistance spiral wires is addressed in our document "The Truth About Ignition Wire Conductors." For more information about our competitors promoting features of their wires that are of no use to anyone but themselves, see our document "A Brief Overview of the Performance Aftermarket Ignition Wire Industry in the USA"We are aware of the MSD demonstration stand, and we certainly appreciate the free promotion MSD gives to our product. We have sold many wire sets to knowledgeable technicians and race and performance street vehicle owners who were previously unaware that ignition wire capable of providing adequate suppression for race and modified engines was available — until they saw the MSD demonstration stand!5. How much extra horsepower can I expect when I fit Magnecor Race Wires ? Professional race engine preparers do not use Magnecor Race Wires to increase engine horsepower — they use them to maintain full engine horsepower. Often, production vehicle owners comment that engine performance increased after they fitted Magnecor Race Wires, and most owners of modified vehicles find that horsepower increases during a dyno test — however, in reality, performance increases because the engine's potential power was previously restrained by:(1) Failing conductors in original equipment ignition wires;(2) Failing conductors in aftermarket carbon conductor and European and Japanese spiral conductor ignition wires;(3) Failing resistor-connectors on German ignition wires;(4) Aftermarket spiral "low-resistance" and "super conductor" ignition wires interfering with the engine's electronics;(5) So-called "built-in capacitor" ignition wires inducing too much available current to ground straps and interfering with the engine's electronics.Despite what is published in advertisements and some vested interest magazine articles, no spark plug wires will generate or "install" additional horsepower. However, a decrease in horsepower will occur if the wires' conductors fail to conduct the spark energy needed to fire spark plug gaps, or EMI emitted from spark plug wires causes the engine management computer to react abnormally, or so much spark energy is lost into the ground straps of so-called "built-in capacitor" wires that little is left to fire the spark plug gaps — see test in Circle Track Magazine (USA), May, 1996 issue. For these reasons, Magnecor Race Wires are used by many successful race teams and individuals all over the world to eliminate the risk of such events occurring.6. Are Magnecor Race Wires expensive ? The price you pay for Magnecor Race Wires can seem reasonable or surprisingly inexpensive for owners replacing original equipment ignition wires. The design and complexity of engines fitted to new production vehicles in recent years has come to rival the engines that were once only available in expensive exotic cars. Reliability up to 50,000 miles can be expected, but the crunch comes when owners discover the cost of maintaining these vehicles also rivals the cost of maintaining an exotic car, and often the absurd price asked for OE replacement ignition wires (that can cost up to US$1,200) causes owners to search for replacement wires that not only cost less, but are of better quality than the original wires that have failed. The result has been owners of these vehicles have been purchasing Magnecor Race Wires, the only ignition wires available for these exotic engines other than the original equipment wires.At the other end of the price scale, Magnecor Race Wires will appear expensive for owners who generally purchase inferior generic spiral conductor ignition wires distributed through mass-merchandisers and speed shops, after wires are branded, packaged and sold as part of a performance parts marketer's product line. For this reason, both our retailers and ourselves are often asked: "Why are Magnecor KV85 Competition and R-100 Race Wire sets more expensive than some other brand performance wires?" The reason is the design and construction of Magnecor Race Wires is entirely different to any other ignition wires on the market. These wires are manufactured exclusively by Magnecor specifically for racing without regard to the cost saving measures used by all other manufacturers who sell their wires through mass-merchandisers and speed shops.Although Magnecor has been manufacturing progressive versions of its suppressed ignition wires for racing engines for over 21 years, it's only in recent years owners of newer vehicles used exclusively on the street have been discovering that Magnecor Race Wires (because of the EMI suppression provided) will improve ignition performance on late model exhaust emission controlled engines. As well, these owners find Magnecor 8.5mm Race Wires will fit into the original 7or 8mm wire retainer/separators because of the flexibility of the aerospace grade silicone rubber jackets Magnecor uses for its Race Wires.However, the popularity of Magnecor Race Wires amongst street vehicle owners has not gone unnoticed by our competitors in the performance aftermarket, and a few have recently introduced oversized "performance" wire sets (some almost identical in appearance to Magnecor 8.5mm KV85 Competition wires) for even the late model small capacity engines that require proper EMI suppression to run satisfactorily. Unfortunately, their wire sets all use the same low-grade ignition cable with the same conductor (that can't properly suppress EMI) they use for older engines that don't require EMI suppression, and their oversized wires can't be satisfactorily fitted into the original 7mm retainer/separators — however, some are cheaper than Magnecor Race Wires! What Magnecor does provide for the price you pay is ignition wires specifically designed and constructed to conduct the full energy output from both original equipment and high out racing ignition systems while providing full EMI and RFI suppression. Magnecor manufactures its own Race Wires, therefore quality is rigidly controlled.7. How long will Magnecor Race Wires last ? The conductors used in all Magnecor ignition cables will outlast the life of the engine unless deliberately severed. The life of ignition wire assemblies relies entirely on the ability of the owner and/or installer to install the wires correctly (particularly on engines designed to make it impossible to easily reach spark plugs), and the need to attach the wires to spark plugs and distributor/coils which are in good working order. The care taken when removing the wires at times when spark plugs are removed and replaced can also affect the life of spark plug wires. On late model multi-valve engines with spark plugs situated in deep un-drained holes, the life of wire assemblies is limited to that of the extended spark plug connectors fitted to the spark plug wires used on these engines
. In turn, the life of the spark plug connectors relies entirely on the ability of the vehicle owner to keep excess moisture and engine oil out of the holes so as not to damage the connectors. The life of any ignition wire will be reduced if fitted too close to extreme heat sources which exceed the heat ratings of the wire assembly's insulating materials. If silicone insulating jackets are cut (sometimes by sharp excess flashing on original plastic cable holders, particularly when 8.5mm cables are fitted in 7mm holders), eventually sparks will leak out of the cut, particularly when engine is under load and/or the spark plugs are aged and/or when the cable is wet.On most Chrysler 2.2 and 2.5 liter 4 cylinder engines where the original design of the distributor uses ignition wire terminals as internal arcing points, the life of the wires is limited to that of the terminals.Specific problems which affect spark plug wire life on certain vehicles are discussed in our technical bulletins.
