i like the cummins engine. the allison tranny is stronger than the others here, but as engoines go, the dodge is superior.i mean, how can you question results likes the tug-o-war. just look at them.
(removed)! I didn't realize it was BS until the pictures finally loaded (yay dial-up) and I saw that the trucks were all toys. That's funny. But they got it all wrong, the one that should have had the bout with spontaneous combustion was not the Chevrolet or the Dodge. hehehe
i believe that the chevy while it actually has just slightly less torque and a little less hp, because of the Allison transmission it will beat the dodge
That is too funny! The Cummins is a great engine! I work with them so I have a bias! Ford engine up until a few years ago was extremely loud and would not pass the Wendys test! I learned about the Wendy's test from International trucks when I worked with them... If a diesel truck could pull up to a Wendys drive through and place an order without shutting off the engine, it passed!
