Fuse Box
Mr. Poopypants
Fuse Box
Post by Mr. Poopypants »
Could they make the fuse box a little more difficult to get to? I had to invert myself on the seat to get to it.
Sub-Vibe-R
Re: Fuse Box (Mr. Poopypants)
Post by Sub-Vibe-R »
The fise box is as easy to go as my previous Cavalier and Ford Escort and (I'm not proud of it) Mercury Topaz.The best place i saw for a fise box was in my Montana.
Mr. Poopypants
Re: Fuse Box (Sub-Vibe-R)
The one in my Lumina Z34 was right inside my glove compartment. It was very simple to get to.
Sub-Vibe-R
quote:The one in my Lumina Z34 was right inside my glove compartment. It was very simple to get to.Same place as my Montana.
satur9
Post by satur9 »
i cant find mine. the book says under dash but i still dont see it .i need very specific directions such as to"right above and to the left of steering column.mabey im blind but i was on the ground legs out the car for fifteen minutes no luck.however i did find a ****load of wires and harnesses under the kick panel hopefully i can find a use for this.as soon as chilton makes a book for us.(i know somebody already makes a 300 dollar book,but i can get skunk2 coilovers for that much)hopes somebody posts the ecu diagram on here real soon.(no pdf).
Sub-Vibe-R
Re: Fuse Box (satur9)
The fuse box is located close your left knee (while driving), right at the back of the left side compatment.
kaybeejay
Re: Fuse Box (silverawd26)
Post by kaybeejay »
I went looking for the fuse box today, and I had no luck. How do you get to it?
2003 Shadow Vibe GT and 2001 Nissan Xterra 4x4
delbaz
Post by delbaz »
I know that your post was made in 2003, but thank G-d I found it because I simply could not find the damn thing, based on the description in the owner's manual. THANK YOU!!!!
