225/55/16?
remusrm
225/55/16?
Post by remusrm »
should i get this? will it be ok... my rim now, steelie, is wider then my tire...
09 MazdaSpeed3 ZOOM-ZOOM
DiveNut
Re: 225/55/16? (remusrm)
Post by DiveNut »
I will be getting a set of Yokohama Avid 225x55x16" installed at Discount Tire Friday morning. The Tech there looked it up and said that they will work just fine. My Contis are almost to the tread wear indicators after just 26,000 miles, so I thought I'd replace them with a better tire that will fill out the wheel wells a bit more that the Stock size.
Bare Bones Base, Abyss 2004 Vibe, Debadged, Auto, ABS, GM Performance Supercharger, Injen CAI, 2.3" URD Pulley, Unichip,Tru-Cool Tranny Cooler SOLD
1972 Plymouth Duster 340 (Strip/Street Project)
DiveNut
Re: 225/55/16? (DiveNut)
Post by DiveNut »
Ooops Correction. I will be getting 225x50x16" tires. Tech told me that the 225x55x16 would cause problems with the front suspension, possible rubbing due to added height.
Raven
Post by Raven »
Quote, originally posted by remusrm »should i get this? will it be ok... my rim now, steelie, is wider then my tire...225/50/16 is the correct size. 225/55/16 is 3.4% too large in diameter. Your speedometer will be off etc.
remusrm
Post by remusrm »
not sure if i am too concerned over the speed.... is ok
Raven
Re: (remusrm)
Post by Raven »
The experts say not to go over 3% difference in size. It can cause brake failure. If you want to buy 225/55/16 because they are cheaper, don't do it. The car will handle a lot better with 225/50/16 anyways.
scherry2
Re: 225/55/16? (Sunny)
Post by scherry2 »
Quote, originally posted by Sunny »225/50/16 is the correct size. how wide are the aluminum 16's? 7" or 7.5" wide?
Raven
Re: 225/55/16? (scherry2)
Post by Raven »
They are 7". I had 225/50/16 on mine for 2 years. It's the maximum for a 7" wheel. He has steel wheels, same width though.
djb383
Post by djb383 »
A taller tire simply places more load on the engine since a taller tire is harder to turn than a shorter tire. Vibe engines need all the help they can get. It would be better to stay as close as possible to the original tire height. I put a set of Goodyear TripleTreds (225/50/16) on my Vibe. This height is virtually identical in height as the original 205/55/16. Goodyear says the acceptable rim width range for the TripleTred in my size is 6" to 8". The back of my factory alloys are stamped 16X6.5.
'05 Lava Tutone base, Pwr Grp, Moon & Tunes, 16" alloys, Auto.....Yep, it's gotta HEMI
turbotoad
Re: 225/55/16? (djb383)
Post by turbotoad »
The stock (16" and 17") alum wheels are 6.5" wide not 7". It has always confused me why car makers design their cars with such skinny wheels. Dodge put 17x6 wheels on the Neon and cruiser. The Scion TC has 17x6's. You can only put a max tire of about 205 (maybe 215) and end up with what look like wagon wheels on the car. The Vibe has a 1/2" wider wheel which should allow you to go to a max width of 225 (235 maybe) and have a better looking stance.
AppleBoy69
Re: 225/55/16? (turbotoad)
Post by AppleBoy69 »
Anyone try 205 60 16"? This is what i just put on my car.Just had triple treads put on my 2005 today cause the conti's are absolute **** in every weather condition. Little bit of snow and evertime i break my ABS comes on!!! And spin everytime i take off!Got 240$ for a trade in on them so that wasn't to bad! Sorry for the sucker who buys them lol.
djb383
Re: 225/55/16? (AppleBoy69)
Post by djb383 »
Have'nt tried 205/60/16 - they may be a little to tall, but I really like the 225/50/16 TrippleTread, which is the same height as original equipment.
remusrm
Post by remusrm »
can i see a pic on how it looks...
djb383
Post by djb383 »
225/50/16 not 225/55/16 (click)
Raven
Post by Raven »
Quote, originally posted by AppleBoy69 »Anyone try 205 60 16"? This is what i just put on my car.Just had triple treads put on my 2005 today cause the conti's are absolute **** in every weather condition. Little bit of snow and evertime i break my ABS comes on!!! And spin everytime i take off!Got 240$ for a trade in on them so that wasn't to bad! Sorry for the sucker who buys them lol. Why did you put 205/60?
AppleBoy69
I put 205/60 16" becuase the the 205/55 16 were 4 - 6 week back order. I needed something now cause of the snow and ice in ontario! So far im very impressed now i need to take a road trip. But at least when there is slush and ice on the road i can actually stop with out my abs constantly comming on!
hotlava
Post by hotlava »
What would be funny to see is a set of old 13" rims from say an old pontiac lemans set up on there. Might be good for a few laughs. I used to have an old 93 lemans and i put some 205/60/r13 tires on it. they looked like balloons on the stock rims but hey, live and learn
