I just bought a 2003 vibe and I want to install a remote start system. I have a prestige 996. I install over 5 remote start unit in the past but my installation book manual just goes to 1999 vehicle and my vibe is 2003. I notice when I remove the cover at the bottom of the steering wheel the ignition wires 14,16 ga, usually ignition wire is much more heavier than that, by the way where is the fuse box? thanks for the help inadvance
The fuse box is under the dash on the drivers side. If you lie on your back on the drivers floor mat and look straight up under the dash you will be looking at it.
http:/theeulogy.wirefire.com2003 Neptune Blue Moon and Tunes4 Speed AutoBluetooth Install(Wifes)2004 Torrid Red GTO Tinted WindowsBluetooth Install0-60mph in 5.2 seconds0-130mph in 22.5 seconds(Mine)
Did you find what you were looking for?If not you can get a wiring diagram at this site:http://www.directwholesale.net...LLDOGThe Vibe has two ignition wires.
