My kit now has a dual stage boost controllerIt also has a centerfeed fuel rail made by SF. I also got an upgraded fuel kit from SF. To see pics of these things, click on the photobucket link in my sig and run the 5 pic slide show. Pause on the turbo bay, and guages pic. In the guages pic, you can see the the boost guage in the a/c vent. You will also see a red light to the left of the steering colum. This is the dualstage boost switch. It switches boost from 6psi to 11psi with one flip. The 6psi is always the lower setting , but I can adjust the highsetting under the hood to whatever i want. Right now it is at 11psi. For the turbobay pic , you can see the air intake going to the turbo at the back of the engine. The white pipes leave the turbo and go to the , (out of sight) intercooler. Then you see the white ic pipe go to the throttlebody. The SF fuel kit is the hexegon thing up by the radiator. You can see the new fuel rail right in front of the valve cover. It is centerfeed , and supplies an even fuel distribution to each injector as my fuel pressure increases under boost.
pics 10/2/05 http://photobucket.com/albums/a386/Faultline05/2003 Base Vibe, frosty color,moon n' tunes packagemods: Eibach sportline lowering springs,17"centerline forged wheels -silver excels -Goodyear Eagle F1 tires 225/50/17's-ACT HD clutch,2.5" exhaust,ES motormount inserts,up graded to 6 spd transmissionStafford Fabrication turbo kit: Garrett T3 turbo, FMIC ,SF BOV. ,Alcohol/water injection,and SF centerfeed fuel rail
Quote, originally posted by XbenwaX1 »Couold you by chance tell me were you bought your kit from i am now looking for a turbo kit for mine.My kit is only offered as an in house install these days. The company is in california sooooo...good luck...check out Matrix owners, they are persuing a kit or two.
