climb in, turn key to ON. now steer left, right, right left, tilt steering up, down, brake, brake gas clutch e-brake. You have just enabled GODMODE for driving your Vibe. Enter the same code backwards to blow up your Vibe.
Quote, originally posted by Mavrik »climb in, turn key to ON. now steer left, right, right left, tilt steering up, down, brake, brake gas clutch e-brake. You have just enabled GODMODE for driving your Vibe. Enter the same code backwards to blow up your Vibe.ha ha ha now what is unlimited gas???
2003 Chevy Silverado Ext. Cab, Z71Formerly2003 Base Vibe (Frosty)
Quote, originally posted by Mavrik »climb in, turn key to ON. now steer left, right, right left, tilt steering up, down, brake, brake gas clutch e-brake. You have just enabled GODMODE for driving your Vibe. Enter the same code backwards to blow up your Vibe.lol. I think CP accidently did that backwards.
INF fuel code isturn key to on, now steer right, tilt wheel up, down, left, left, horn, gas, brake, gas, gas.If done properly, you won't flood your engine and you have unlocked the inf fuel cheat.
Quote, originally posted by GMJAP »lol. I think CP accidently did that backwards.Hmm, I think that may not be far from the truth. I've been known to experiment with buttons/etc. on most electronic consumer devices to find hidden menus and the like. This is the first I've heard about Mav's cheat code, so very likely that I have tried the evil option without ever knowing it. Silly me! At any rate, that's a lot of motions to go through just to turn off your stability/traction control schtuff. One thing I was questioning the second I saw this, do they not have a button that turns the stuff off like just about every other vehicle I've seen with such a system? I see in the comments following the article that it does allegedly have one, but after reading those most hilarious comments, I don't really believe what I read there anyway. If that is the only way to disable it... At least it isn't as complicated as our remote programming procedure which makes you do the hokey pokey. That wouldn't be much fun to have to do every time.
Up, Up, Down, Down, Left, Right, Left, Right, B, A, B, A, Select, Start...Oooh! I just added 100 more HP to my Vibe!
Jen's Vibe:: 2004 two-tone base in Frosty :: Automatic :: Exhaust Tip :: Rear Bumper Protector :: Cargo Nets :: Rear Cargo Mat :: Rear Cargo Cover :: "You just got passed by a wagon " decal :: Red glowing "No Smoking" plug in cigarette lighter ::
Quote, originally posted by Jaycie685 »Up, Up, Down, Down, Left, Right, Left, Right, B, A, B, A, Select, Start...Oooh! I just added 100 more HP to my Vibe!only 100?left, left right, down, down, up, honk, gas, e-brake up, e-brake down, left, gas, start car, turn radio up, select heavy metal.You have now added 700whp and 700 torque.
Quote, originally posted by Mavrik »only 100?left, left right, down, down, up, honk, gas, e-brake up, e-brake down, left, gas, start car, turn radio up, select heavy metal.You have now added 700whp and 700 torque.Hahahah yeah that's better!
Quote, originally posted by Jaycie685 »Up, Up, Down, Down, Left, Right, Left, Right, B, A, B, A, Select, Start...Oooh! I just added 100 more HP to my Vibe!Man... I was just thinking that. Hahahaha Contra, good times.u u d d l r l r b a b a start!
Quote, originally posted by russ257 »http://www.realtechnews.com/posts/2176this is so sweet i wanna go test drive one and then do thisthink the salesman would freak?Doing the disable routine probably would just get his attention... the way you drive after that would probably put him/her over the edge.This is why you insist on testing alone or with your spouse... no salesmen on test drives - or no sale.
