Fuel gauge light and reserve
Vibe-agra
Post by Vibe-agra »
I have only filled up my tank twice on my new Vibe. I have put in 10 and 11 gallons thinking I was on the verge of running out of gas. It seems the gauge works opposite my last car, where the gas gage starts to fall immediatly after fill up and leaving a large reserve at Empty. Has anyone figured when the low fuel light comes on? I'm thinking at about 10 gallons used.
Mikey2003 Pontiac Vibe Base, 4-speed auto, Abyss, monotone, Moon and Tunes, Power package, in-dash 6-disc CD, ABS, Side curtain Air-bags, Security System, Cargo box,Cargo mat, s/s exhaust tip. Ching Ching1996 Honda ST1100ABS
esjones
Re: Fuel gauge light and reserve (Vibe-agra)
Post by esjones »
quote:Has anyone figured when the low fuel light comes on? I'm thinking at about 10 gallons used. That jives with my experience over about 5 tankfuls.- Earl
- Earl Earl Jones, Sales and MarketingHorizon Systems LLChttp://www.horizonsystems.com/ Skype ID: esjonesMy Vibe: '03 Base, 5-speed, ABS, Alum. Wheels, Power Pkg, DVD Nav., Security, Neptune/Graphite
Sub-Vibe-R
Re: Fuel gauge light and reserve (Salsa!)
Post by Sub-Vibe-R »
The reserve is about 10 liters (2.6 galon)I went to the gas station right away the light came on and I put 40 liters in it.
coratz
Re: Fuel gauge light and reserve (Sub-Vibe-R)
Post by coratz »
at exactly 580km-590km for the past 3 tanks my low fuel light has come on. i have driven with the light on up to 738km. when the light comes on you have between 9-11 liters left of gas. the needle can go aprox a quater tank under the "e" line. i can tell when im really empty and floor it and you get a bit of bogging, at that point i say damb its cold out but im not gonna push!!!!
cohocarl
Post by cohocarl »
I filled mine up about 10 miles after the low fuel light came on, and I put in 11.4 (U.S.) gal.
Stang2Vibe
Re: Fuel gauge light and reserve (silverawd26)
Post by Stang2Vibe »
Mine seems to come on with about 2.5 gallons left in the tank.
abronco1
Post by abronco1 »
Thanks for the info, I tried looking in the Vibe manual (online version) to find out that exact info, so thanks for the heads up!
NeptunePlastic Cladding5-speed manual17 inch RimsPower PackageABS Bumper GuardRear Cargo MatRear Cargo CoverThe Simpson's Steering Wheel Cover!! I love it!
canadavibegt
Post by canadavibegt »
quote:I try not to run mine low, I always fill up when it is around 1/4 of a tank left.I with you....... i try to never let it fall below 1/4 to an 1/8 at most.... i do not trust fuel guages so ikeep track of millage as well........ BTW with fuel injected engines it is not good to run them relay low on fuel.... Electric fuel pumps do not like to pump fumes... they tend to heat up and can fail or shut off temporarly.
Canada Rocks View pics of my car here. http://www.cardomain.com/member_pages/v ... _id=345207
ragingfish
Re: Fuel gauge light and reserve (canadavibegt)
Post by ragingfish »
quote:I with you....... i try to never let it fall below 1/4 to an 1/8 at most.... i do not trust fuel guages so ikeep track of millage as well........ BTW with fuel injected engines it is not good to run them relay low on fuel.... Electric fuel pumps do not like to pump fumes... they tend to heat up and can fail or shut off temporarly.I was gonna say the same thing. I've been told it's bad for the engine to go with less than 1/4 tank, because in winter, condensation can form and freeze, and possibly rupture a fuel line or something, or in general, at that level, the supply isn't always steady, and it can screw with the EFI.
2009 PONTIAC G8
ragingfish
Ah well, I was close.
2009 PONTIAC G8
