Put a set of Hella 500s on so I can see the cows that like to stand in the road, hopefully in time to avoid them.I don't think they look as ugly as my wife thought they would. I had to mount them high enough so the rabbits won't knock em off.Wired them so they would cycle on/off with the high beams also put in a dash mounted switch to keep them turned off. This was a good thing I found out later when the daytime running light came on and the dash switch was on...it cycled the driving lights relay about 3 times per second. Hmm the daytime driving lights sytem supplys voltage to the high beams. This "feature" has probably been discussed here before.
