alarm/remote starter
mcgusto82
Post by mcgusto82 »
ok, i bought this universal alrm and starter. had this guy my father recomended do the job. he claims to have extensive experience. i would question this after the attempted instalation. he said he could not fit the alarm because of the side markers switch triggered a ground insted of a positive signal. the alarm on the other hand triggers a positive signal. he says most alrms offer a positive or negative signal. this one i had, only offered positive. so he tells me that i need to find a alrm that offers both.so, is this true. are the blinkers triggered by ground?
idontknowwhatimdoing
Re: alarm/remote starter (mcgusto82)
Post by idontknowwhatimdoing »
Not true in any way at all........he needs to change a positive into a negative pulse via a relay or vice-versa. You do not need to change alarms, just installers. ANY installer with any experience would know the work around off the top of their head.
Chop it channel it bag it...even a shopping cart can look coolerhttp://www.eblackdesign.com3/10/06 ... Thanks for the good times '03 Vibe GT ... The '05 Matrix XRS now has the honor.
mcgusto82
Re: alarm/remote starter (idontknowwhatimdoing)
Post by mcgusto82 »
this hadn't occur to me. i think this time i will do the job myself.i have never done an alrm before though. but from seeing the guy doing it. i think it isn't that difficult.the guy defenately wasn't equiped. he did it right outside his house.i would appreciate all the help posible. anybody out here in tri area NY wana give me a hand. i'll buy you lunch.
Jahntassa
Post by Jahntassa »
Hey, i've done alarms and remote starts right outside my house, so don't knock that!Some alarms do only offer positive output for the door triggers, they're quite rare though. But, as said, simple relays will solve that issue.
