Any one put on one of those third break light stickers that say vibe on them? If so was it hard to do? Or any suggestions...putting it on tonight!
Toodles! ATHF "She's the kind of girl u bring home to your Mother. She looks good in blue jeans, even better under covers. She's a devil in bed between the sheets, ask her if she's a saint & she'll get down on her knees and pray....yeah..yeah...yeah." BlueJeans http://profiles.yahoo.com/fortiffany
Just got mine from Ryan Saturday--need to have the bf come help install it. I got the inside mount rather than the outside mount, so I'm curious how that will go.
it goes on easy, i just popped the glass then put it up with a tiny bit of soapy water and then squeegied it out, but then i parked it outside and it got VERY cold and bubbled a little
Is it still bubbled like that? Was it a inside or outside one?
yea i got to excited and installed them saturday :/ i used a blow dryer but then parked outside over night and in the morning there were some little bubbles, ill try a needle and see if i can get it fixed...or just take the hit and buy new ones next summer.
Well don't I feel dumb. I had my friend from work come over to help me put it on my car and then I found out that all you have to do with the one I got is just stick it on the actual break light its self. I told him I was just being a typical girl. I could have done it all by myself but no I had to make it way harder than it was. I guess I just thought that it went on the inside of the glass on the window. Now I really don't like this one and don't suggest it at all. I don't know if they changed the size of those lights on the new Vibes but I started on the right side and then when I got to the left there was about a 1-2 inch gap where the sticker was not big enough Also the letters a a little large and when you close the window then that silly cover thing goes around it and you really can't see all of the letters.
I will get a pic on here as soon as I can find someone to step on my break for me while I take a pic! Did anyone else have this problem? Or have this sticker that goes on the light its self?
Typically they go either on the inside of the glass or on the outside of the glass. I had an outside mount that I did the same as you in mounting it onto the light itself. I had gaps and then used black electrical tape to cover them. It was off center so I replaced it. I now have an inside glass mount and would highly recommend it.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
Where did you find that one? It goes on the inside of the glass...the part were you take off that little cover thing right?
Quote, originally posted by fortiffany » I found out that all you have to do with the one I got is just stick it on the actual break light its self. I told him I was just being a typical girl. I could have done it all by myself but no I had to make it way harder than it was. I guess I just thought that it went on the inside of the glass on the window. Now I really don't like this one and don't suggest it at all. I don't know if they changed the size of those lights on the new Vibes but I started on the right side and then when I got to the left there was about a 1-2 inch gap where the sticker was not big enough Also the letters a a little large and when you close the window then that silly cover thing goes around it and you really can't see all of the letters. sounds to me like you got the one that goes on the outside of the window and put it in the wrong spot. the only 2 i've ever heard of go on the glass, either outside or inside.
No it really goes on the light...the paper that came with it said so...I went over it a billion times. I was thinking it was going to look all rippled because of the light not being flat. It worked I just don't like it. I thought that it was the one that goes on the glass but the wrong stide was sticky.
Quote, originally posted by fortiffany »Where did you find that one? It goes on the inside of the glass...the part were you take off that little cover thing right?I got it from Ryan at Grafxwerks.comYes, inside after you take the thingy off.
My Fleet:
Well thanks I will be looking into that... Added a pic of the one I have now...see that little gap...urggggg!
