I had a thread about how I installed heated seats. http://forums.genvibe.com/zerothread?id=19626 In that post I had several people asked about the outlets I had added during the process. I know this is not a big deal but if someone searches for outlets they will find this thead and it might help them. So let me explain what I did. First I needed an ignition switch power source for the seat heaters. I used the wire that was feeding the dash 12 volt outlet because it was ignition switched and was protected by a 15 amp fuse. I also wanted the dash outlet not to be switched. So I ran a 15 amp fused wire from the fuse box in the engine compartment to the dash outlet. Using this new power feed, I also added an additional outlet at the front of the center console for items I wanted to remain on like our laptop GPS and I prefer not to have that wire hanging from the dash.
