vibe GT-R???
mcgusto82
vibe GT-R???
Post by mcgusto82 »
ok, it's not a GT-R. it's my vibe. i finally made a functional hood scoop.here is the run down.i spent the better part of a day priming it, painting it, and clear coating it.small enough as i wanted it.i used a drill and 1/2" bit to make the saw insertion points.the frame work under the sheet metal wa a little difficult to cut. the saw's blade wasn't long enough to reach the lowest point. had to snip it with a metal scissor.the scoop before it goes over the cavity.after getting the cavity done, i prepered the exposed metal. used the primer i had used the night before i painted the scoop. with a brush i made sure i got all the bare metal. don't want corrosion to ruin the job later on.the scoop is attached by a strip of double sided cushiom tape going around. i added a 1" strip at the front for further protection. the whole job without the painting took me 3 hours.the painting was a whole day basically.my RAM CAI is in the mail. i think the whole RAM scoop isn't going to work as planned.due to the contours of the hood, i had to move it further to the center of the hood. it should still be functional. it won't be ram air thoughso waht do you guys think?
rlfreese
Post by rlfreese »
very unique. any plans on getting it fiberglassed to look like it is part of the hood. great idea and it looks similar to gt-r specs.
2005 Base Vibe W/ moon and tunes , piaa headlight/foglight bulbs, tein s-tech suspension, cosmo CAI, TRD quickshifter, ES motor mount bushings, magnaflow exhaust, RK sport CF roof rack caps, tinted windows, kenwood KDC-X589 HU/w remote Cardomain Page http://www.cardomain.com/ride/797307
BlueCrush
Re: vibe GT-R??? (mcgusto82)
Post by BlueCrush »
That is about as close to a GT-R hood as you are going to get. Nice work. I see you had to cut the structural brace on the underside of the hood. 1) Does the hood feel more flimsy now? 2) Is there a screen on the scoop?3) Is the opening right over where the Short Ram filter will be located?If so, you might be want to be concerned about water entering the filter and causing your engine to hydrolock. You may also want to rig up a cover/plug for the hood scoop for driving in the rain and snow. You have some kahunas, man. I would never do that to my only hood. I would have bought a hood from a salvage yard and modified that one so I knew I had an oem one to fall back on when I screwed the modified one up. It looks good. The paint is almost a perfect match.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
4X4CHICHI
Re: (rlfreese)
Post by 4X4CHICHI »
I like it, I bet with some custom fab work you could make it functional. might have to do some kind of fiberglass or rubber cowling. oh and by the way, what is that rocket thingy?
2004 FUSION ORANGE VIBE GT200 Watt CD & XM radio, Tinted windows17" Black Casino'sSilverstars Head and Fog, Injen C.A.I.http://www.cardomain.com/memberpage/453424
zionzr2
Re: (4X4CHICHI)
Post by zionzr2 »
Quote, originally posted by 4X4CHICHI »I like it, I bet with some custom fab work you could make it functional. might have to do some kind of fiberglass or rubber cowling. oh and by the way, what is that rocket thingy?Its this:Quote, originally posted by mcgusto82 »you want spinners??? i got spinners for you.that rocket's turbine at high speed diffuses my air drag and saves me on mileage.
4X4CHICHI
Re: (zionzr2)
Post by 4X4CHICHI »
uuuhhh.....
BOZACK
Re: (4X4CHICHI)
Post by BOZACK »
That looks very cool. Nice job. Maybe after you get the short ran in you could create something to divert the wind to the intake.
Monotone Neptune, pow pac, 17" stock rims, K&N air filter, bumper guard, custom pedels, brake light cover, billet oil cap
Mavrik
Post by Mavrik »
NICE! yeah when your short ram is installed, fabricate a shield of sorts to direct the air to it. Any thoughts on water getting in though?
mcgusto82
Re: vibe GT-R??? (BlueCrush)
Post by mcgusto82 »
mcgusto82
Post by mcgusto82 »
Quote, originally posted by BlueCrush »That is about as close to a GT-R hood as you are going to get. Nice work. I see you had to cut the structural brace on the underside of the hood. 1) Does the hood feel more flimsy now? 2) Is there a screen on the scoop?3) Is the opening right over where the Short Ram filter will be located?If so, you might be want to be concerned about water entering the filter and causing your engine to hydrolock. You may also want to rig up a cover/plug for the hood scoop for driving in the rain and snow. You have some kahunas, man. I would never do that to my only hood. I would have bought a hood from a salvage yard and modified that one so I knew I had an oem one to fall back on when I screwed the modified one up. It looks good. The paint is almost a perfect match. i WAS planning on doing this shield.http://forums.genvibe.com/zero...r.JPGa plastic bucket cut to hold the ram intake and keep it from getting hot air. to keep the water out.. i was going to drill holes on the bottom. 1: the hood doesn't feel clumsy at all. the sheet metal collapses more with weight over it. it did it before, it does it alittle more now. not worried about structure rigity. will get a strut bar soon anyways.2: no, screen was not included with the scoop. i might try and make one. not a priority.3:no, the opening is not right over the air intake. it isn't possible unless you mold it in. (i'm cheap. hence doing it myself.)however the opening IS right over the battery positive terminal. i ned to get a batery cover. unless in heavy storm. water would just drizzle down. it might even evaporate. i stuck my hand inside after coming from SAM'S club. it's very hot around that area.it isn't possible to place the scoop there because of the hoods contour. the scoop is made of rigid abs plastic and won't properly stick with the contours. i had to place it over a flat enough area. i have a little experience on manufacturing and fixing structure material from my navy times. even painting."(removed)! what are you doing to my hood?" - my wife.
mcgusto82
Post by mcgusto82 »
on a related note. i removeed the tubing going from the filter box to the intake behind the headlight. the cars makes considerately more noise under load. almost sounds like a custom muffler job.not sure how i feel about it. i suppose the ram intake will make the same noise.with the scoop being there it was ideal to remove that tube. let the filter box get the cool air above it.
silver_vibe
Re: (4X4CHICHI)
Post by silver_vibe »
Quote, originally posted by 4X4CHICHI »uuuhhh.....ditto.
Celtic_Curse
Post by Celtic_Curse »
I like....welcome to the club.
2003 Supercharged 5spd Vibe BaseGM Supercharger + TRD ECUMagnaflow Cat Back + DC Sports Header 18" AXIS rimms w/Kumho TiresTop Spoiler + Vis CF Functional Scoop
JustinVGT
Re: (zionzr2)
Post by JustinVGT »
Quote, originally posted by zionzr2 »Its this:Yeah, what is that little rocket thing? I don't get it.
mcgusto82
Re: (JustinVGT)
Post by mcgusto82 »
just a little thing i found at a "auto zone". it was on the clearance table. it was my hood center peice. i'm thinking about taking it off.
JustinVGT
Re: (mcgusto82)
Post by JustinVGT »
Darn, so it doesn't really diffuse the air and improve your gas mileage? Bummer. J/K Hey, if you like it, keep it. I was just curious what it was. You did a good job with the hood scoop, paint looks to match well. Did you just use the auto touch up spray paint you can find in auto shops? Like someone said before, you are brave to do that to your original hood. I would have wanted to try it out on some hood from a scrap yard or something.
BlueCrush
Re: (mcgusto82)
Post by BlueCrush »
Quote, originally posted by mcgusto82 »just a little thing i found at a "auto zone". it was on the clearance table. it was my hood center peice. i'm thinking about taking it off.It is clashing with the hood scoop. Move it to the roof just in front of the sunroof if you still want to keep it.
My Fleet:
mac99d
Re: (BlueCrush)
Post by mac99d »
Looks good. from me
Mac's Vibe.
