CEL ON more than OFF!
Vibedad
Post by Vibedad »
Have a Cosmo on my 05 Base that has worked great with only a few problems in 6 months. Now, about every other day, my CEL is ON! A quick check with the dealer found it to be related to air flow so I know it's my CAI. I have checked all the connections as well as the filter and all seems OK. When I reset, I let the car idle for at least 15 minutes.Has anyone else experienced this?Where should I look or what should I do?
Vibedad 2005 Base Vibe, Abyss, 5 spd, Moons & Tunes, all options but leather, Tinted, Cosmo CAI, Megan STB, Tein S Lowered
Lancer
Re: CEL ON more than OFF! (Vibedad)
Post by Lancer »
What type of air flow problem?Check to make sure that the MAF is on correctly and not backwards.Clean the air filter.Clean the MAF sensor.If you still have a CEL on, put the stock air box in for a while and see if it comes back. Good luck!
zionzr2
Post by zionzr2 »
something to try:1. disconect battery overnight2. reconnect battery 3. start car and let idle for 5-10 minutes
Vibedad
Re: (zionzr2)
Post by Vibedad »
Will the long battery disconnect make a difference? I just don't know what effect this would have.
Vibedad
Re: (Vibedad)
Post by Vibedad »
Checked my paperwork from the Dealer. Code set was PO171 - diagnose cause of lean condition.Codes cleared and retested 5% @ idle
Lancer
Re: (Vibedad)
Post by Lancer »
You only need to disconnect the battery for about 15-20 minutes to completley clear the CEL. But it's easy to do and there's no harm in leaving it off overnight.I doubt that just a CAI would be the cause of a lean condition bad enough to throw a CEL. Try some fuel injector cleaner and run some higher octain gas through your system and see if that helps.
goodvibe
Post by goodvibe »
Did you oil the cosmo filter as recommended? You may have oil on the MAF. It won't need much with the CAI that already runs a bit lean. Reset when finished and cross fingers.
Vibedad
Re: (goodvibe)
Post by Vibedad »
Oiled when first installed which was back in May, so I doubt that would be the problem now. I will try some injection cleaner to see if it helps. I also noticed that the hose that runs from under the plastic engine cover into the CAI had a very tight bend in it. I am wondering if it was crimping so I have rerouted it. Do not know if that would have caused this problem though. What is that hose for?
