our engines also have the potential to put the power to the ground. these things are very well designed. too bad we have a granny tranny messing them up.
2005 Base Vibe W/ moon and tunes , piaa headlight/foglight bulbs, tein s-tech suspension, cosmo CAI, TRD quickshifter, ES motor mount bushings, magnaflow exhaust, RK sport CF roof rack caps, tinted windows, kenwood KDC-X589 HU/w remote Cardomain Page http://www.cardomain.com/ride/797307
Quote, originally posted by rlfreese »our engines also have the potential to put the power to the ground. these things are very well designed. too bad we have a granny tranny messing them up.So, I'm not the only one noticing this?!?
nope, on top of being a Force Protection Officer i am also a Technician for the army as well. I have studied many eingines and ours is probably the best 4 cylinder design i have seen besides the suby boxer engine. and our ttanny needs a good swap. sombody needs to do research and see if we can swap the 6sp Vibe Gt/ Matrix XRS and Celica GT-S tranny or at least the celica GT 5 speed for better performance fpr us non gas friendly people.
Quote, originally posted by rlfreese » sombody needs to do research and see if we can swap the 6sp Vibe Gt/ Matrix XRS and Celica GT-S tranny or at least the celica GT 5 speed for better performance fpr us non gas friendly people.So I assume what you're interested in on the GT/XRS tranny is the higher Final Drive Ratio?I didn't understand why it would be better at first (first and top gear ratios are the same), but I'm guessing this would be why?
Quote, originally posted by rlfreese »correct, not to mention that a 6 speed would be cool to have in a base vibe or xr. but the celica gt tranny wold even be better than ours.I'm confused. I believe the Vibe trannies are from the Celica.?EDIT: The 2005 Celica GT-S has the same gear ratios and final drive ratio as the Vibe GT / Matrix XRS
Interesting that the version of the 1ZZ in this paper uses an "exhaust header" style intake manifold, as did the Oldsmobile Quad four in its early days...
The .pdf is dated for February, 1998. But, I believe our engines are the second or third version of the 1ZZ. So it could very well be that it the design is used from an earlier version.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
no, our engines are from the celica, the tranny is different. the celica has more performance potential where ours is economicaly designed for gas mileage. gearing is different.
Quote, originally posted by rlfreese »no, our engines are from the celica, the tranny is different. the celica has more performance potential where ours is economicaly designed for gas mileage. gearing is different.The specs I've seen show the same 6spd gear ratios and final drvie ratio...??
Quote, originally posted by rlfreese »no, our engines are from the celica, the tranny is different. the celica has more performance potential where ours is economicaly designed for gas mileage. gearing is different.I did some research once and found the the model for the celica and MRS tranny mated to the 1zz is the c56. The tranny mated to the 1zz Vibe/matrix/corrolla is the c59. The diference between the c59 and the c56 is that 3rd and 4rth gear are different. 1st 2nd and 5th are identical, but 3rd and 4th are taller in the Vibe. In the celica , 4 gear is direct drive where in our car it is an over drive gear. I may put a matrix xrs, or vibe gt 6 spd in some day. It should bolt right up. The celica gt-s 6spd trannys bolt up to the 1zz celicas.
pics 10/2/05 http://photobucket.com/albums/a386/Faultline05/2003 Base Vibe, frosty color,moon n' tunes packagemods: Eibach sportline lowering springs,17"centerline forged wheels -silver excels -Goodyear Eagle F1 tires 225/50/17's-ACT HD clutch,2.5" exhaust,ES motormount inserts,up graded to 6 spd transmissionStafford Fabrication turbo kit: Garrett T3 turbo, FMIC ,SF BOV. ,Alcohol/water injection,and SF centerfeed fuel rail
Quote, originally posted by Faultline »I did some research once and found the the model for the celica and MRS tranny mated to the 1zz is the c56. The tranny mated to the 1zz Vibe/matrix/corrolla is the c59. The diference between the c59 and the c56 is that 3rd and 4rth gear are different. 1st 2nd and 5th are identical, but 3rd and 4th are taller in the Vibe. In the celica , 4 gear is direct drive where in our car it is an over drive gear. I may put a matrix xrs, or vibe gt 6 spd in some day. It should bolt right up. The celica gt-s 6spd trannys bolt up to the 1zz celicas. Interesting. Thanks for posting that.
