VW wheels for snow tires?
Andrew-4ce
Post by Andrew-4ce »
Does anyone know if the 15" VW 5x100 wheels will fit the Vibe with a 195/65/15 on it?Thx
AKLGT
Post by AKLGT »
the wheels should fit, but don't know on the tires. check tirerack's tire calculator.
AKLGT1998 Subaru 2.5RS
Altus
Re: VW wheels for snow tires? (Andrew-4ce)
Post by Altus »
Yup - fit perfectly
2003 Shadow Vibe -- Alloys, Auto, and Allota fun!Vibe #4,873Sadly, traded-in for a 2005 Dodge Grand Caravan
Andrew-4ce
Thx!
goodvibrations
Post by goodvibrations »
My friend had a set of 15" VW 5x100 winter rims with a 195/65/15 Tires from a 2000 VW Jetta. I tried them on my 2005 Vibe and the rims fit however the centre hole seemed to be a little larger, when I tried it on my vibe. I did know if that makes a difference once you tighten the bolts. Might be something you want to check. May have just been just those rims.
2005 Neptune Vibe automatic,, power group.
LavaMyVibe
Re: VW wheels for snow tires? (goodvibrations)
Post by LavaMyVibe »
Quote, originally posted by goodvibrations »My friend had a set of 15" VW 5x100 winter rims with a 195/65/15 Tires from a 2000 VW Jetta. I tried them on my 2005 Vibe and the rims fit however the centre hole seemed to be a little larger, when I tried it on my vibe. I did know if that makes a difference once you tighten the bolts. Might be something you want to check. May have just been just those rims. There are several opinions around various forums about hubcentric (where the wheel sits on the rotor hub) and boltcentric (where the wheels and hence the entire vehicle is supported by the bolts rather than the hub) wheels. Some say that if your wheel is boltcentric that you should be using hubcentric adapters. Others say that as long as the lugnuts are tightened properly while the wheel is off the ground (so that the bolts pull the wheel centered) that you should be ok. I'm of the opinion that you should use hubcentric wheels because the bolts on our cars are not designed to support the full weight of our vehicles for extended periods of time. Or use adapters to make them hubcentric. This of course depends how much room there is between the rotor hub and the wheel hub.
Lava Vibe GTwheel lockshome made cargo matbaby seat15 " Pirelly Winter Carving tiresbrass shifter bushing
