hey there all, just wondeirng what the best way to get power back to the rear storage compartment on the passanger side.I would prefer running as 8 or 10AWG form the battery?thanks hings on the path to take this run woudl begreat.......thanksWill
Don't suppose you could do Driver side? Save yourself a little wire..Easiest way through the firewall is through the main wiring grommit above the gas pedal..
maybe a power block splitter. get power to the under the dashbord. then from there, you can divert to wherever you want. that way you can still add power to other parts of the car without snaking the whole car.
