greddy emanage..does anyone have it
rlfreese
Post by rlfreese »
does anyone here have a E-Manage. I want to know what will add more power, the E-Manaage, SAFC II, or the camcon. and also which one last longer without being interupted by stock ecu settings.
2005 Base Vibe W/ moon and tunes , piaa headlight/foglight bulbs, tein s-tech suspension, cosmo CAI, TRD quickshifter, ES motor mount bushings, magnaflow exhaust, RK sport CF roof rack caps, tinted windows, kenwood KDC-X589 HU/w remote Cardomain Page http://www.cardomain.com/ride/797307
BlueCrush
Re: greddy emanage..does anyone have it (rlfreese)
Post by BlueCrush »
SAFC will not work it get overridden by the stock ECU. Camcon is still in testing on MatrixOwners with good results so far. I have an e-Manage that I was trying to install with an AutoSportWiring harness and the directions are crap. After trying many different wiring configurations I gave up and sent it down to Black_TRD it Puero Rico to take a look at it since he has that set-up on his Matrix.The three that will work fo far on the Vibe and Matrix are: Unichip, e-Manage and Camcon. Unichip and e-Manage control just about everything except the rev limiter and VVT. They control the three major things that are needed to get more out of our engines: A/F ratio, Injector Duty, Ignition Timing. The Camcon only controls that A/F ratio and VVT. But it may be possible to use the e-Manage with the Camcon to control everything.I also, sent my e-Manage that I bought off e-bay to Matt @ MWR to get a N/A tune. They do offer a N/A tuned e-Manage set-up for $369.Unichip does the same thing but need to be tuned but them adn it costs around $775.I will hopefully have my wiring harness back next week and then re-install my e-Manage.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
rlfreese
Post by rlfreese »
great response. I will probably get the e-manage in due time and will go with the camcom for now. just post a how to if you can on the emanage. I dont want problems like you had.
