Found a 1ZZ-FE Center Feed Fuel Rail
BlueCrush
Post by BlueCrush »
I know there were a couple people looking for one of these:http://www.jmfengineering.com/...s_all
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
rlfreese
Post by rlfreese »
what is the purpose and does it add any performance to the car.
2005 Base Vibe W/ moon and tunes , piaa headlight/foglight bulbs, tein s-tech suspension, cosmo CAI, TRD quickshifter, ES motor mount bushings, magnaflow exhaust, RK sport CF roof rack caps, tinted windows, kenwood KDC-X589 HU/w remote Cardomain Page http://www.cardomain.com/ride/797307
BlueCrush
Re: (rlfreese)
Post by BlueCrush »
It is mainly used for FI applications to provide more fuel for larger injectors.
My Fleet:
rlfreese
Post by rlfreese »
so this wont help a na motor at all.
BlueCrush
Re: (rlfreese)
Post by BlueCrush »
Probably not. The stock rail should be more that sufficient. Even if you are going to be installing an aftermarket piggyback ecu such as a Unichip or e-Manage and increase the flow of fuel using those, it should still be more that sufficient.
My Fleet:
Lancer
Re: (rlfreese)
Post by Lancer »
It also has a port that you can use for nitrous or a fuel pressure gauge. Been looking at that. Maybe for Christmas.
Faultline
Re: (Lancer)
Post by Faultline »
Quote, originally posted by Lancer »It also has a port that you can use for nitrous or a fuel pressure gauge. Been looking at that. Maybe for Christmas.You can also use that port to run a return fuel line. I believe the easiest way would be to return it to the filler tube of the gas tank. I know that I am getting stuck on my own ideas, but with a return fuel line you can use a rising rate regulator when doing force induction. For every pound of air pressure you rise, the regulator rises 1 pound of fuel pressure. If you run 10 psi of air pressure into you motor, then the regulator raises the fuel pressure 10 psi. Which is exactactly back to stock perameters for fuel pressure. It gets more fuel out of your injectors at less duty cycle. I have one of these fuel rails and I suppose the hardest thing about them is installing them correctly, I understand that you want to get new O-rings so that the fuel does not leak from the new rail.
pics 10/2/05 http://photobucket.com/albums/a386/Faultline05/2003 Base Vibe, frosty color,moon n' tunes packagemods: Eibach sportline lowering springs,17"centerline forged wheels -silver excels -Goodyear Eagle F1 tires 225/50/17's-ACT HD clutch,2.5" exhaust,ES motormount inserts,up graded to 6 spd transmissionStafford Fabrication turbo kit: Garrett T3 turbo, FMIC ,SF BOV. ,Alcohol/water injection,and SF centerfeed fuel rail
