size of moons and tunes package Sub
kimchimik
Post by kimchimik »
what's the size of the stock sub for the moons and tunes package?
Jahntassa
Post by Jahntassa »
I think it's an 8"
rlfreese
Re: (Jahntassa)
Post by rlfreese »
it is an 8"
2005 Base Vibe W/ moon and tunes , piaa headlight/foglight bulbs, tein s-tech suspension, cosmo CAI, TRD quickshifter, ES motor mount bushings, magnaflow exhaust, RK sport CF roof rack caps, tinted windows, kenwood KDC-X589 HU/w remote Cardomain Page http://www.cardomain.com/ride/797307
restanim
Post by restanim »
The M&T Sub ia a 6.5" dual voice coil woofer. Each vioce coil is rated at 2 ohms @ 50 watts. I know this because I took mine out and actually measured it.If you read it is an 8", 10" or maybe 12", it is wrong. The woofer is 6.5". Hard to believe to see that a subwoofer is a 6.5" driver.
joejoev
Re: (restanim)
Post by joejoev »
Quote, originally posted by restanim »The M&T Sub ia a 6.5" dual voice coil woofer. Each vioce coil is rated at 2 ohms @ 50 watts. I know this because I took mine out and actually measured it.If you read it is an 8", 10" or maybe 12", it is wrong. The woofer is 6.5". Hard to believe to see that a subwoofer is a 6.5" driver.restanim,Do you recall how much room there is back behind the monsoon panel? Specifically the depth?Is there enough space to install an 8" or 10"?
restanim
Post by restanim »
joe,are you aking with or without the monsoon sub enclosure?The sub enclosure has right around 3" of mounting depth. Without the enclosure, and mounting a sub to the interior panel, you could probably add anothe 2". Keep in mind that the sub needs an enclosure to sound proporly.
joejoev
Re: (restanim)
Post by joejoev »
Thanks for the info, restanim. This is my first visit back to the forum since my question. My sub project has been on hold. Just too much going on lately.The depth with and/or without the enclosure is exactly what I needed. I don't want to spend the money on a new panel not knowing if I could even use it. Maintaining as much cargo space as possible is critical for my line of work, so I will be doing a free air installation.
