How do you select XM channels directly in the factory XM radio??
skitime
Post by skitime »
OK I am new to this car and XM. I have been unable to find this info in the owners manual. How do I select a channel like 145 directly without just holding the seek or scan button until that channel goes past? Surely the must be a way to punch in numbers to get to a channel number. With 247 channels there must be a better way. Thanks
BlueCrush
Re: How do you select XM channels directly in the factory XM radio?? (skitime)
Post by BlueCrush »
Nope, you have to use the seek/scan button unfortunately.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
ragingfish
Post by ragingfish »
Quote, originally posted by skitime »OK I am new to this car and XM. I have been unable to find this info in the owners manual. How do I select a channel like 145 directly without just holding the seek or scan button until that channel goes past? Surely the must be a way to punch in numbers to get to a channel number. With 247 channels there must be a better way. ThanksJust curious, but seeing how the radio only has buttons numbered 1-6, how do you suppose it would be done?
2009 PONTIAC G8
ZubenElGenubi
Post by ZubenElGenubi »
Use the "Tune/Select" knob below the volume knob. It'll zip you around all the stations pretty quickly.Screengrabs from owner's manual:
ZubenElGenubi
Re: How do you select XM channels directly in the factory XM radio?? (ZubenElGenubi)
...also, once you're ready to choose your presets (you've got 12), space them so that you can use them to get to others around the dial.Ex. I've got a preset on 44 (Fred) so I can click over once to 45 (XM Cafe). I've also got a preset on 175 (Home Plate) and then I just scroll through the MLB channels afterthat.
skitime
Post by skitime »
Thanks ZubenElGenubi that was good info. Guess I need to get more organized with this radio. I never used the tuning knob for some reason just the seek and scan knob. Good to find a faster way.
