s/c question.
heha
s/c question.
Post by heha »
for those lucky enought o have a s/c out there, has your f/c dropped? and if so how much? Im just wondering if its worth to save up and get it or just trick the car out different ways?
sometimes madness is confused with passion.......but is there any other way to live?
BlueCrush
Re: s/c question. (heha)
Post by BlueCrush »
f/c (Fuel Comsuption) will drop because you will be boosting. If you can keep the RPM's under 3000 you should get close to what you get now. when in boost you are throwing more fuel into the engine thus your gas milease will go down.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
damronjr
Re: s/c question. (BlueCrush)
Post by damronjr »
Quote, originally posted by BlueCrush »f/c (Fuel Comsuption) will drop because you will be boosting. If you can keep the RPM's under 3000 you should get close to what you get now. when in boost you are throwing more fuel into the engine thus your gas milease will go down. Nuff said!
heha
Post by heha »
ok then....thats what I figured but I wanted to make sure that my f/c would be horribly decreased with everyday driving. I think im sold on saving up for one now.bluecrush again thanx for the advice
goodvibe
Re: (heha)
Post by goodvibe »
I don't have experience here but I know that the SC runs rich to help keep things cool so I would expect a significant mileage decrease seeing how you would be using more fuel even with optimum A/F.
