Cargo Mat with Sub?
Pontiac, GM SPO (Service Parts Organization) & TRD (Toyota Racing Development) discussions
Savageone79
Cargo Mat with Sub?
Post by Savageone79 »
If you have the 05 vibe and the sub in the back do you need a special cargo mat? If so where can I find it?Thanks!
tnpartsguy
Re: Cargo Mat with Sub? (Savageone79)
Post by tnpartsguy »
I didn't find anything on gmgoodwrench.com, but I am not at work, and don't have my new parts catalouge installed yet. I promise I'll get back to you by Monday noon at the latest, but hopefully sooner. I'd go install the catalouge now, but I need my laptop for other things this evening, and it takes a few hours to load up the 1st time (2 dvd's).
You will need a different mat with the sub... Here's a thread about it.http://forums.genvibe.com/zero...72958
stevo2000
Post by stevo2000 »
I haven't received mine yet, the parts guy at the dealership said it was a factory direct order and that it would take a few weeks. After doing quite a bit of research we determined that the part number would be #17800790, also found some references in other posts.The number is listed at gmgoodwrench.com under cargo mats, but the description states that it is a custom front mats, which looks to be wrong. We decided to take the chance and ordered the part number, hoping that it is the correct product.
2005 Platinum Base, Automatic, Moon & Tunes, Power Doors & Windows, Factory installed XM Radio, ABS w/Tire Pressue Monitors, Airbags, Security System & Leather, 16" Alu wheels...
ShadowRuleZ
Re: Cargo Mat with Sub? (stevo2000)
Post by ShadowRuleZ »
That's the right number, look at my post (linked above). I already received mine.
stevo2000
Re: Cargo Mat with Sub? (ShadowRuleZ)
Post by stevo2000 »
I'll confirm that number. Received mine and it fits.
mexigrl
Post by mexigrl »
So does that mean if I have the Moon and Tunes Package w/XM then I have to get a different mat?Thanks (newbie here...only one day old (the car not me!))Mexigrl
kostby
Re: Cargo Mat with Sub? (mexigrl)
Post by kostby »
Hope this explanation helps:For '05 Moon & Tunes (with or without XM) has the rear 'Monsoon' subwoofer in the right passenger-side cargo area that is a different shape than the rear panels of the '03-04's. The '03-04 mat is symmetrical, thus the '03-04 rear cargo mat WILL NOT not fit '05's WITH Moon & Tunes (but it will fit '05's WITHOUT Moon & Tunes)That's why this discussion thread exists, and the new part number for '05 cargo mats is listed in this thread!
mexigrl
Re: Cargo Mat with Sub? (kostby)
Post by mexigrl »
Does the same thing hold true for other cargo accessories? I did see the stock number for the mat. What about the cargo holder and/or nets? Would those be the same as for any other Vibe?Thanks!Mexigrl
jwalcik
Post by jwalcik »
i can't speak to the cargo holder, but the cargo nets work just fine with the M&T sub.
2005 vibe gt
the_nite_owl
Post by the_nite_owl »
What's the deal with the sub anyway? I have an 05 with Moon & Tunes, have not seen one without.Is the panel on that side larger than that of one without so the mats have to be cut differently? Seems like a lot of extra tooling for GM just to incorporate the sub.
stevo2000
Post by stevo2000 »
I have the Moon & Tunes, Carpets, Nets, Rear Seat Storage and Cargo Carrier. See attached Picture..
binary
Post by binary »
Quote, originally posted by stevo2000 »I have the Moon & Tunes, Carpets, Nets, Rear Seat Storage and Cargo Carrier. See attached Picture..Checked every box on the build sheet, eh?
