What Have You Done?
Pyro-Andrew
What Have You Done?
Post by Pyro-Andrew »
hey there! i have a base Vibe! and i was wondering what you have done to your enngine? besides the usual supercharger and the like? i mena like ungrading the cam shafts, changing hte gears shafts, and others to do with the guts.....im trying to get mine to run better, cleaner, and more horses.....thanx!!!
Have: 2006 Pontiac Torrent. Perferred Package. Sun & Sounds Package. Blue Streak Color. Sirius Radio.
Shadow-Vibe
Re: What Have You Done? (Pyro-Andrew)
Post by Shadow-Vibe »
Check out http://www.monkeywrenchracing.com!! I need some money before I purchased something from them.
Pyro-Andrew
Re: What Have You Done? (Shadow-Vibe)
THANX MAN! THEY AINT GOT NOTHING IN the pontiac side, but the matrix/vibe under toyota has got some cooool stuff!
Shadow-Vibe
You can also check out there engine packages for the 1ZZ and 2ZZ they are the same for us as they are for the matrix and MRS!!
Bobssbase04
Post by Bobssbase04 »
Has anyone been to Monkey Wrench? When they did my flywheel/ckutch. There was 2 mr2's there. Then thier Mr2 which is wicked with it's turbo. Then they had just installed a turbo on a Lotus Elise that some guy just bought and dropped it off their. So they have all kinds of stuff for the Matrix and Vibe.
2004 Base Trix 5-speed Camcon with Boomslang harnessJP Performance header/high-flowcat/mid pipe comboMonkey Wrench flywheel ACT HD clutchMagnaFlow axle backAEM CAIEnergy Suspension motor bushings
