JVC Headunit Problems with M&T
McVibe
Post by McVibe »
I just got a really nice HU from JVC and installed it but when I did, the only music I could hear was out of the Subs in the back. This is obviously some problem because of the Moons and Tunes set-up but I don't really know for sure. Can someone tell me what I need to do to make this work? You know, cut a few wires here and there, splice a little...
2004 Vibe Base Cosmo Racing CAI (Orange) Eurolite Xenon Headlights, foglights, reverse light, Licence Plate Lights and Dome Lights:star: JVC KD-DV5100 Headunit 7" Sharp LCD 2 12" Legacy 500w Subwoofers 400w Legacy Amp Custom Bult Sub box 3 Pillar pod Gauges Painted Engine Cover Jom Billet Aluminum Stubby Anntena
ragingfish
Re: JVC Headunit Problems with M&T (McVibe)
Post by ragingfish »
You need to trigger the outboard amp to come on.Connect pin B3 on the car side (the only pin that has TWO wires coming out of the back of it - tap either wire) to the amp turn-on signal from the headunit.
2009 PONTIAC G8
McVibe
Re: JVC Headunit Problems with M&T (ragingfish)
Post by McVibe »
Works great! Thanks a load!!!
McVibe
Post by McVibe »
So yea, sound is coming thru the speakers now but I have found another problem...There is a noticable hiss coming out of the tweeters that wasn't there before. I tryed messing with the equalizer but the hiss was still there. And it's not engine noise either, as I played the CD player when the key was in the ign. at acc. Any idea or is it time for me to get new tweeters or crossovers, or what ?
ragingfish
That's the quality of your delphi sound.Also, make sure you're using a line level converter. Otherwise, your sound is double-amplified and sounds like a$$.
2009 PONTIAC G8
rlfreese
Post by rlfreese »
yeah, the line level converter is great. Thanks raginfish for letting me know that in my thread as well. I just connected the amp signal wire from the radio to the amp signal wire from the wire harness and it worked great. love my kenwood acdrive headunit
2005 Base Vibe W/ moon and tunes , piaa headlight/foglight bulbs, tein s-tech suspension, cosmo CAI, TRD quickshifter, ES motor mount bushings, magnaflow exhaust, RK sport CF roof rack caps, tinted windows, kenwood KDC-X589 HU/w remote Cardomain Page http://www.cardomain.com/ride/797307
