PIAA lights.
DopeVibeGT
PIAA lights.
Post by DopeVibeGT »
Just installed a set of PIAA Xenon HID lights on my GT, and must say, I like them! They ran me a pretty penny, but are guaranteed for a year against blow out. They have a very slight blue/purplish HID look to them, and are bright! Now my driving lights look yellow. As soon as my camera's batteries charge and I get a chance, I'll post pics.
DopeVibeGT
Re: PIAA lights. (DopeVibeGT)
Ok, here's a picture. The camera lense must have been foggy, or something, but you can tell the difference in the headlights and the driving lights.
msmyer
Post by msmyer »
I was going to get these....you have the part number? You order them on-line? or from a store? Thanks!
‘03 Vibe with 317k and still going.............................
Other Mods: Sony X-Plod Headunit & Reflective White GVC decalMy Car at Cardomain.com... http://www.cardomain.com/id/msmyer
DopeVibeGT
Re: PIAA lights. (msmyer)
Part #15560 model# H-76E H4's. I picked them up at my local speed shop. And they are almost exactly the same brightness and shade as the real thing. I was beside a car last night that had factory ones, and they both lit up the road about the same.
NY Pete
Post by NY Pete »
You referred to these PIAA Super Plasma bulbs as HID's which isn't really correct, you're liable to confuse people. They're just regular incandecent bulbs, with a different halogen gas mixture and tinted glass to give it a HID LOOK. Real HID's don't have a filament and work by producing a metal-gas arc at extemely high voltage levels which requires the use of a seperate voltage transformer...
'02 Jetta 1.8T Silver Arrow/Black Leathuh - Neuspeed turbo inlet pipe, 17" VW Exor wheels, euro Bora tails, Neuspeed Sofsport Springs, Bilstein HD's, Da'lan hitch'03 20thAE GTI #3494 Imola Yellow/Black Recaros - Omori/AWE boost gauge, HPA Motorsports Short shifter, Neuspeed 28mm rear sway, REVO programming, Neuspeed turbo inlet pipe, FK Badgeless grille, Kamei eyelids and one big fat grin
DopeVibeGT
Re: PIAA lights. (NY Pete)
Uuuuummmmmmmmmm....I know. I'm just telling you what it says ON THE CASE. I know what true HID lights are, and if someone thinks they can convert to HID lights for $80 and two bulbs, they are way past confused and I cant help them. Thanks.
DopeVibeGT
Re: PIAA lights. (Salsa!)
I doubt it. Doesnt say DOT on it. Just have to change them back to plain old boring Halogens when inspection time rolls around.
NY Pete
Post by NY Pete »
I think some of the lower-color-temperature PIAA lamps are DOT approved (Super Whites are the only ones that come to mind)...
DopeVibeGT
Re: PIAA lights.
Some newer pics without the snow. You be the judge if the 5000k is worth the $$.
DopeVibeGT
And the highs....
