I have a complete, and virtually unused, set of mounted and balanced snow tires from my previous car. They are 175/70/R13. Could I use them safely on my new '05 Vibe this winter or are they too small?
'05 Lava monotone, AWD, 3/5ths debadged, Weathertech mats and ventvisors, homemade cargo mat
As long as they match the lug pattern they will fit. But I would worry that they would be too small for the Vibe. The Vibe would ride lower if the overall diameter is smaller. Also the smaller rims would look really bad in the large wheel wells of the Vibe. IMO.
Monotone Neptune, pow pac, 17" stock rims, K&N air filter, bumper guard, custom pedels, brake light cover, billet oil cap
You really can't do 13's.The lowest you can go AFAIK is 15. The outer diameter being smaller will also throw the speedometer off, in addition to lowering the car's ground clearance.I would NOT do it if I were you.
175/70/13 is 9% smaller in diameter.60mph would show up as 66mph on your speedometer. 3% is the recommended maximum difference in size. Here is a link to a tire size calculatorhttp://1010tires.com/TireSizeCalculator.asp
That's true. Also, I don't think 13's will clear the brakes.Quote, originally posted by ragingfish »You really can't do 13's.The lowest you can go AFAIK is 15. The outer diameter being smaller will also throw the speedometer off, in addition to lowering the car's ground clearance.I would NOT do it if I were you.
