Pipe Sizes for a Base Vibe Vs GT vibe
kimchimik
Post by kimchimik »
Is there a size difference between the GT and Base's exhaust pipe sizes?
Mase
Re: Pipe Sizes for a Base Vibe Vs GT vibe (kimchimik)
Post by Mase »
From the cat-back...no size difference. They're both 2" stock. The flange lines up a little differently between the two models though.
kimchimik
Post by kimchimik »
thank you very much. Was seeing if a GT pipes would help out on my base but looks like i might have to look into someting aftermarket any ideas other than the magna flow?
Emerica13
Re: ... (kimchimik)
Post by Emerica13 »
Quote, originally posted by kimchimik »thank you very much. Was seeing if a GT pipes would help out on my base but looks like i might have to look into someting aftermarket any ideas other than the magna flow? Yeah, run straight pipes
2003 Shadow Vibe GT
Mase
Re: ... (kimchimik)
Post by Mase »
Magnaflow is currently the only true mass-produced cat-back exhaust system. There's no difference between the GT and base model magnaflow exhaust either.I personally would recommend getting a custom exhaust. All you need to buy is the muffler and resonator. a good exhaust shop should be able to take care of the rest.
