optima battery
darcmater
optima battery
Post by darcmater »
I was lookinf at the optima battery websight and they don't list a battery for the matrix/vibe, but i recall seeing pic's of vibes with yellow top optima batteries in there. Anyone know if the there is an optima battery that fits into the vibe, or if some modification is needed?
hippyvibe
Post by hippyvibe »
I know for a fact that you can put an Optima Yellow Top in a Vibe (GT at least) because that's exactly what mine had in it the day I test drove it (blue ground wire kit and all!) but then the service department jacked all that >| along with the amp for the subs! Dirty SOBs.
2003 Mono Abyss GTMoon and Tunes, 17 " Sport Max 929, Eibach Pro SpringsDunlop 215 50/RZ17 tires oem, SoundStream Rubicon 1000w, two CF1044 10" subs, GM Top Rear Spoiler, AEM Short Ram intake Blue, Progress Rear Anti Roll bar, Flowmaster Delta Flow 60 Series, Denzo IK 20 5304 plugs, TRD STB Front, Brass Bushings
BlueCrush
Re: optima battery (darcmater)
Post by BlueCrush »
I have a yellow top in mine but I had to get post extensions to get it to work. Think you can order one that will work better but I don't know the model number. If you do a search you should find the info you are looking for:
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
AKLGT
Post by AKLGT »
the red top fit fine. it was plenty enough power. yellow top would work too, but may be a little excessive. 720 cca is good and i had no problems at all. yes, i know. the engine was a bit dirty. lol. now my red top's in my LGT. great battery!
AKLGT1998 Subaru 2.5RS
illusion
Post by illusion »
There's a lot of info in this thread: http://forums.genvibe.com/zerothread?id=9508
-jkhttp://360.yahoo.com/illusion1
darcmater
Re: optima battery (illusion)
Post by darcmater »
Just got a responce from optima is the red top 35 or the yellow top D35. I was looking on ebay fro cheap ones and found some as low as like $60, that seem to be sold by companies. The price kinda concerns me becasue its so cheap compared to what stores sell them for.
AKLGT
Post by AKLGT »
when purchasing ANYTHING from ebay, check the sellers info and feedback, and also look at how much they will rape you on shipping. i can't imagine it cheap to ship a battery! go to costco or your local battery store if you want to make sure it fits correctly and you get your warranty.
darcmater
Re: (trdvibe)
Post by darcmater »
ok i seem to need those post extensions but none of the auto places by me see to have any or know what they are. any help?
BlueCrush
Re: (darcmater)
Post by BlueCrush »
You can get them online at Checker Auto. You will need two parts. The extension: http://www.partsamerica.com/Pr...LCST2The post: http://www.partsamerica.com/Pr...STCP2Or you should be able to find these at your local auto parts store.
My Fleet:
AKLGT
Post by AKLGT »
i didn't need any extensions other than the the little plastic "booster seat" for the battery. it came with it so no probs.
darcmater
Re: (trdvibe)
Post by darcmater »
thanks got the parts i needed, incase u haven't noticed my techical expertise is limited : ). Thats why i love this forum, lots of people to get info from.
tangerine
Post by tangerine »
If your getting this battery for your sterio system remember one thing, you want yellow if you draw alot of current with car off and red if car is on.
04 Fusion Orange Base Vibe auto Now no longer with us thanks to ignorant drivers...
jake75
Re: (tangerine)
Post by jake75 »
Looking at the Sears site, there were two battery numbers for the Vibe1. Group 35 9 11/16 x 6 7/8 x 8 3/16 36 lbs2. Group 26R 8 3/4 x 6 3/4 x 7 3/16 31 lbsAuto Zone - Duralast also listed 35-DL 550 CCA and 26R-DL 575 CCAIs this an either/or or do you just look to see what's in there now?Sears ad today - price was $54.95 but looks like they charge $12.95 to install.Who sells the Optima?? Buying on e-Bay the shipping would kill any savings.
zionzr2
Post by zionzr2 »
Optima available at Batteries Plus, AutoZone, and others
tangerine
Post by tangerine »
Stinger>Optima
darcmater
Re: (tangerine)
Post by darcmater »
just to save people the hastle i had, make sure the sales man gives u the 35 not a 75/35. the diff is that the terminals are reversed on the 35 so that they are at the far back of battery so the cables will reach and be on right side. This was why i had such an issue at first
AKLGT
Re: (tangerine)
Post by AKLGT »
Quote, originally posted by tangerine »If your getting this battery for your sterio system remember one thing, you want yellow if you draw alot of current with car off and red if car is on.yep, sounds like i'm going to have to get the yellow top then. i guess i should have double checked. that might explain why i had such a problem with my mobile desk drawing too much power.
heha
Post by heha »
noob question here.what does this change or make better? is it a mod that is highly recommended?
sometimes madness is confused with passion.......but is there any other way to live?
AKLGT
Post by AKLGT »
it just allows you to run higher powered items like a/m stereo, amps, any a/v systems, etc. the stock battery since you have an 05 will be ok if everything is stock. if you do anything else though, then you may want to get a better battery.
heha
Post by heha »
i have an 04. so does that change anything?sorry to ask so many questions
Jahntassa
Re: (heha)
Post by Jahntassa »
Quote, originally posted by heha »i have an 04. so does that change anything?sorry to ask so many questionsOnly thing it changes is you probably have the 540 CCA battery instead of the 310.As far as replacement battery? No, probably not.
