K&N typhoon intake system
rasermon
Post by rasermon »
Typhoon Installation Instructions in PDF format. 2003 Toyota Matrix XRS & 2003 Pontiac Vibe GT L4-1.8Lhttp://www.knfilters.com/typhoon/69-8601.pdf Too bad it's a short air Intake.
DABEAR95
Re: K&N typhoon intake system (rasermon)
Post by DABEAR95 »
I'm seriously considering this intake. I had good luck with my two previous K&N offerings. They both improved performance noticeably.FIPK for 99 Eclipse GS-T SpyderFIPK for 95 Camaro Z28
2003 Vibe GT Lava w/accent + 17'' wheels2002 VW Golf TDI 43City/52Highway lifetime1995 Camaro Z28 CAI,!TB,Airfoil,Shorty Headers,!CAT,Borla exhaust, 3.73's w/eaton posi. 13.5@105 with 245/50/16 Michelin XGT's = no traction
Lorin
Re: K&N typhoon intake system (DABEAR95)
Post by Lorin »
I wish I could find a before / after dyno chart on this product....It sounds like an easier install than the Injen.
Lorin2003 Pontiac Vibe GT, Neptune-mono, moons & tunes, power package, side impact airbags, rear seat covers, bumper protector, cargo mat.Mods installed: TRD exhaust, TRD stb, Mods removed: TRD CAI - annoyed by CEL
DABEAR95
Re: K&N typhoon intake system (Lorin)
Post by DABEAR95 »
Lorin, I would expect its performance to be similar to all other high flow filter kits. Since its a shorty type, maybe 3-8HP at the wheels is my "guess".Jason
rasermon
Post by rasermon »
quote:I'm seriously considering this intake. I had good luck with my two previous K&N offerings. They both improved performance noticeably.After thinking about it, I'm also considering the typhoon intake. I installed a fuel injection performance kit (Gen ll) on my Sonoma 99 Highrider, the increase in horsepower was awesome.
PBFlash
Post by PBFlash »
This does look nice and seems easy to install but for less money you can buy the Injen or AEM intake and get more HP. They may be a little harder to install but the lower price and more HP should make up for it.
Satellite Vibe GTMoons and Tunes Package with 6-Disc In Dash CD, Safety/Security/Power Packages, cargo mat. 35% tint all around (except windshield)18 in Motegi Racing MR8 Wheels/Nitto NT 555 225/40ZR-18 tiresStainless Steel Exhaust TipInjen CAIPics of my Vibe CarDomain.com
Lorin
Re: K&N typhoon intake system (PBFlash)
Post by Lorin »
I think I probably will end up with an Injen intake. Right now, I only have 300 miles on the car and I'm still developing my upgrade strategy on what I want to upgrade first. I've already ruled out an exhaust - almost no bang for the buck. I probably will start with the Injen, then add either a strut brace or rear sway bar. Then on to sound...The biggest problem is I'm enrolled in an MBA program besides working full time, I have to plan my upgrades around my class schedule!
mu_ohio
Post by mu_ohio »
quote:This does look nice and seems easy to install but for less money you can buy the Injen or AEM intake and get more HP. They may be a little harder to install but the lower price and more HP should make up for it. The Injen isn't hard to install if you have a buddy and a little patients. If you want a short ram intake, you can always get one from AEM I believe.
2004 Pontiac GTOPhantom Black w/black leather
ragingfish
Post by ragingfish »
I was seriously consdering installing a CAI...I've had this rush of "mod my car!" energy since I successfully changed out my horns. But this looks waaaaaay to complicated and risky...and if the Injen or AEM are harder, then (removed)!Can anyone tell me, for a person who has NEVER messed with their engine (I don't even know how to change my own oil), is trying to put this in just asking for trouble?
2009 PONTIAC G8
PBFlash
Re: K&N typhoon intake system (ragingfish)
Post by PBFlash »
I think the instructions look harder than it actually is. I think anyone with some basic mechanical skils should be able to do it without a problem.
ragingfish
define basic mechanical skills? loli've never worked under the hood of a car...
2009 PONTIAC G8
Mr. Poopypants
Post by Mr. Poopypants »
This may sound like a dumb question but will the base Vibe take the same intake? I have not seen a GT engine compartment and I am not sure if they are set up the same. And I don't want to spend the $$$$ if it will not work for my car.
NovaResource
Re: K&N typhoon intake system (Mr. Poopypants)
Post by NovaResource »
No, the base vibe and the GT have different engines and use different intakes.
mu_ohio
Post by mu_ohio »
quote:define basic mechanical skills? loli've never worked under the hood of a car...Basically, you have to find all the bolts that hold down the air box and undo them. Disconnect the various sensors and then slowly pull the unit out. Installing the new one is easier since you know what has to be mounted and which parts to reuse. On a scale of 1 to 10, this would be a 2 or 3. I consider a one being changing headlights or something simple to 10 being a turbo kit.
ragingfish
Re: K&N typhoon intake system (mu_ohio)
Very tempting to just go at it...just afraid I might break somethign or screw it up and then the car will be annhilated, and THAT would not be covered under warranty, now would it. lol.
2009 PONTIAC G8
Mr. Poopypants
Re: K&N typhoon intake system (NovaResource)
quote:No, the base vibe and the GT have different engines and use different intakes.Is there an intake for the base Vibe? (preferably K&N)
NovaResource
Yes, K&N makes kits for base and GT Vibes:2003 PONTIAC Vibe - 1.8L L4 F/I: 69-8600TB2003 PONTIAC Vibe - 1.8L L4 F/I: 69-8600TP2003 PONTIAC Vibe - 1.8L L4 F/I: 69-8600TR2003 PONTIAC Vibe - 1.8L L4 F/I: 69-8600TS2003 PONTIAC Vibe GT - 1.8L L4 F/I: 69-8601TB2003 PONTIAC Vibe GT - 1.8L L4 F/I: 69-8601TP2003 PONTIAC Vibe GT - 1.8L L4 F/I: 69-8601TR2003 PONTIAC Vibe GT - 1.8L L4 F/I: 69-8601TSTB = Typhoon kit, blueTP = Typhoon kit, polished aluminumTR = Typhone kit, redTS = Typhoon kit, satin aluminum
