Remote Auto Start Modules
eilros
Post by eilros »
I just got quotes from 3 dealers in town to install 2-way LED remote starters. Two carry AstroStart (model 2205) and the other carries Viper (model 571XV). I've received different answers from all three regarding the number of modules needed for a 2004 Vibe. The Viper dealer said that I need two modules at $50/ea while one AstroStart dealer said I needed one and the other said I didn't need any. I double checked with each one and their answers remainded the same. Does anyone on this board have experience installing either model? Obviously I don't want to waste $50-$100 if I don't have to.Thanks,Dave
2004 Satellite Base
Jahntassa
Post by Jahntassa »
No extra modules for the Vibe. There is no passlock in the key, the door locks are standard negative-pulse just like a Toyota.I personally like Vipers, and have one on my own Vibe. I installed it as well, as I used to work at Circuit City.
eilros
Re: (Jahntassa)
Post by eilros »
Quote, originally posted by Jahntassa »No extra modules for the Vibe. There is no passlock in the key, the door locks are standard negative-pulse just like a Toyota.I personally like Vipers, and have one on my own Vibe. I installed it as well, as I used to work at Circuit City.Thanks for the info Johntassa.
2004 Satellite Base
binary
Re: (Jahntassa)
Post by binary »
Quote, originally posted by Jahntassa »No extra modules for the Vibe. There is no passlock in the key, the door locks are standard negative-pulse just like a Toyota.I personally like Vipers, and have one on my own Vibe. I installed it as well, as I used to work at Circuit City.How difficult is it to install? I can handle tracing wires, pin outs, and the like. How much time did it take you? And the final question - was it worth it?
tahoejeff
Re: (binary)
Post by tahoejeff »
i had mine installed by bestbuy, but just to have the remote in our cold (removed) wisconsin winters is worth many hours of labor. i can walk up to a window 15 mintues before i get out of work, push a button, and start my car. very little scraping while my coworkers are scraping and cussing.
ragingfish
Re: (binary)
Post by ragingfish »
Quote, originally posted by binary »How difficult is it to install? I can handle tracing wires, pin outs, and the like. How much time did it take you? And the final question - was it worth it? If you choose a Viper, it has to be installed by a certified installer. Otherwise, your warranty is null and void. Jahntassa is one, so he was able to do his own. If you go with any other brand, you can likely do it yourself. It takes time, but can be done.
2009 PONTIAC G8
Abyss AWD
Post by Abyss AWD »
I was a tech for Hyundai several years back, and we installed remote starters, I have found the AstroStart Units to be superior in Quality compared to the Vipers.There are too much Hype in Viper products. their good ones are their 2 ways. but those can get pretty expensive.
eilros
Re: (Abyss AWD)
Post by eilros »
Quote, originally posted by Abyss AWD »There are too much Hype in Viper products. their good ones are their 2 ways. but those can get pretty expensive.I'm going to get the LED 2-way and the Viper is $100 more than the AstroStart.
2004 Satellite Base
4X4CHICHI
Re: (eilros)
Post by 4X4CHICHI »
I have installed 2 of them. One in an '89 Dodge Rraider and one in a Toyota Camry. Both were pretty straight forward. but, I will admit that cutting that ignition wire the first time can be a little scary. Most of them come with installation videos now.
2004 FUSION ORANGE VIBE GT200 Watt CD & XM radio, Tinted windows17" Black Casino'sSilverstars Head and Fog, Injen C.A.I.http://www.cardomain.com/memberpage/453424
