Pics needed: Stock tweeter wiring
ragingfish
Post by ragingfish »
As I continue my "restockifying" efforts, I've come to a crossroads at which point I need help of the community.Can someone with an 03/04 M&T setup (manufactured BEFORE 12/2004) take a picture of either stock tweeter for me (remove the sail panel, of course). I had cut the wiring off them to install my aftermarkets, and now I need to reinstall them, but can't tell for the LIFE of me which terminal on the tweeters is positive and which is negative. They aren't labeled or in any way differentiated.All i need to know is which terminal has the wire with the strip going to it...Thanks in advance!
2009 PONTIAC G8
ragingfish
Anyone?Bueller?Cahmon....it'll only take a hot minute!
2009 PONTIAC G8
Re: Pics needed: Stock tweeter wiring (ragingfish)
Just let it go back with a four speaker system. hehShouldn't they work either way? I've hooked speakers up umpteen times before the wrong way and they still worked... But I dunno, ain't no audio guru.
ragingfish
It *does* produce sound either way, but I'm not sure that it's technically *supposed* to go the "wrong" way. Something about phase maybe? I dunno...
2009 PONTIAC G8
Re: (ragingfish)
Yeah, I guess you're right... There's probably a capacitor inline somewhere to act as a filter, whacking all frequencies below a certain point. There, I guess proper polarity would be a good idea.Look at you, all wantin' to make sure that everything is done right and stuff. If it were me, I'd be half-arsing the stuff since my car is only worth fifty cents anyway. I wish I could help ya, but if I take the door panel off one more time, it won't go back on properly. I've already broke the damn tweeter panel so it won't stay where it needs to stay.
ragingfish
Anyone else???
2009 PONTIAC G8
the_sarge
Re: (ragingfish)
Post by the_sarge »
Did the M & T change for '05? If not I can help ya..
bud_one
Post by bud_one »
how bout this ?? might help.....
McVibe
Post by McVibe »
Okay, I did this before I went to work this morning and was pretty tired but I hope this helps
2004 Vibe Base Cosmo Racing CAI (Orange) Eurolite Xenon Headlights, foglights, reverse light, Licence Plate Lights and Dome Lights:star: JVC KD-DV5100 Headunit 7" Sharp LCD 2 12" Legacy 500w Subwoofers 400w Legacy Amp Custom Bult Sub box 3 Pillar pod Gauges Painted Engine Cover Jom Billet Aluminum Stubby Anntena
JustinVGT
Re: Pics needed: Stock tweeter wiring (bud_one)
Post by JustinVGT »
Sorry Mike, can't help you with providing a pic since I have my aftermarket setup.About this wiring diagram, I am pretty sure I am reading it correctly that it shows the wires coming out of the amp for the tweeters and I don't think that is correct. When I installed my sub last weekend I tapped into the speaker outputs and there are only 4 pairs. Like Colonolpanic mentioned above, there is probably a capacitor inline some where filtering out the low frequencies.
ragingfish
thanks mcvibe, unfortunately, that does NOT help. oddly enough. is yours an 04? Mine does not have that capacitor on the speaker, and the wires are soldered to the two outer terminals with the center remaining unused.
2009 PONTIAC G8
McVibe
Re: (ragingfish)
Post by McVibe »
Yea, mines an 04, bought it early 04 too...thats odd. Could you have removed the capacitor when you installed the other tweeters?
Jahntassa
Post by Jahntassa »
You wouldn't happen to have the Nav system, would you McVibe?The M&T setup doesn't need caps on the tweeters as the crossover is built into the amplifier..As for having the speakers connected backwards, if one is wired opposite of the other, it throws them out of 'phase', which makes everything sound wierd (laymans terms). Tweeters, though..shouldn't be too badly affected.
McVibe
Re: (Jahntassa)
Post by McVibe »
Nope, I'm too poor for navigation , I got a single CD regular M&T setup.
