Is the 5 speed manual tranny the same in the Vibe and the Matrix?
SBC31
Post by SBC31 »
I'm not very happy with the shifting in the 2005 Vibe, and was wondering if they use the same tranny as the Matrix, or is it a GM one?Thanks in advance.
SBC31.COM
ragingfish
Re: Is the 5 speed manual tranny the same in the Vibe and the Matrix? (SBC31)
Post by ragingfish »
same.
2009 PONTIAC G8
SBC31
Re: Is the 5 speed manual tranny the same in the Vibe and the Matrix? (ragingfish)
Post by SBC31 »
Thanks for the info... I did think they were the same, but am surprised how loose the shifter feels given it's from Toyota. Nothing like my Honda.
SBC31.COM
ragingfish
Auto here, so I wouldn't know. Drove a GTO one day though, that shifter was TIGHT! And I don't mean that in the street sense, as in tight = awesome, cool, hip, but as, that puppy shifts and snaps right into gear.
2009 PONTIAC G8
Faultline
Post by Faultline »
What exacty are you un happy about?The Vibe and matrix have a model # that is called the c59.The celica and the mr2 spyder have a 5 spd that is the c56. The difference is that in our Vibe/matrix tranny 3rd and 4th gear are different than the celica one. 1st , 2nd and 5th are identical. In the celica, 3rd is a little bit shorter and 4th gear is direct drive. In the Vibe, 4th gear is an over drive gear, just as 5th gear is. The celica , even though lighter, gets worse gas mileage than our car, and the gearing is part of the reason. If you want even more of a sport geared car, then the 6speed is the best. It will fit right up I am told. The gearing for the Vibe GT, Matrix xrs, and celica GT-s are identical. If you simply dont like the shifter, do a search, I think that some people were adding/ replacing shifter bushings. .
pics 10/2/05 http://photobucket.com/albums/a386/Faultline05/2003 Base Vibe, frosty color,moon n' tunes packagemods: Eibach sportline lowering springs,17"centerline forged wheels -silver excels -Goodyear Eagle F1 tires 225/50/17's-ACT HD clutch,2.5" exhaust,ES motormount inserts,up graded to 6 spd transmissionStafford Fabrication turbo kit: Garrett T3 turbo, FMIC ,SF BOV. ,Alcohol/water injection,and SF centerfeed fuel rail
Jahntassa
Post by Jahntassa »
I changed out the bushings on my GT. It does make the shifting MUCH tighter, but it also removes a lot of the room for error.. I need to track down a short-shifter, I think, for the best performance out of it..
rlfreese
Post by rlfreese »
i have a base 5 speed with trd shifter and bushings and it is nice, i mean nice. try that out. oh and by the way, did you say the 6 speed will bolt right up to the 5 speed engine. that would be nice too.
2005 Base Vibe W/ moon and tunes , piaa headlight/foglight bulbs, tein s-tech suspension, cosmo CAI, TRD quickshifter, ES motor mount bushings, magnaflow exhaust, RK sport CF roof rack caps, tinted windows, kenwood KDC-X589 HU/w remote Cardomain Page http://www.cardomain.com/ride/797307
