Non-working low beams
bluvibe
Post by bluvibe »
Last nite I discovered that my low beam headlights on my 03 are not working - had to drive home wit the driving lights. I checked the DRL fuse, which is OK, checked one of the bulbs, no evidence of it being burned out. I ollked at the headlight relay, but since it's sealed, I couldn't have seen anything. Any suggestions? Does the car have a sep. relay for hi/low beams?Thanks!
2005 Frosty- M & T- h/k drive+play
My other Pontiac: http://www.64tempest.com" onclick="window.open(this.href);return false;
ragingfish
Re: Non-working low beams (bluvibe)
Post by ragingfish »
Did you check the headlamp fuses under the hood?Have you done anything to the headlamp system lately that could have caused an overload?
2009 PONTIAC G8
redlava
Re: Non-working low beams (ragingfish)
Post by redlava »
The lights might have just simply burnt out. Try replacing them before you start tearing the car apart.
ragingfish
He indicated the bulbs were not burnt out.
2009 PONTIAC G8
redlava
Re: (ragingfish)
Post by redlava »
Whoops guess I should read a little more slowly.
