Device Under Driver's Seat
Cajun
Post by Cajun »
Does anyone know what the device under the driver's seat does?
Sub-Vibe-R
Re: Device Under Driver's Seat (Cajun)
Post by Sub-Vibe-R »
AC converter for the 120v power outlet
KSNeptune
Post by KSNeptune »
And if you think the AC outlet doesn't have enough power for certain devices you want to use, there are other inverters with more power. You could replace thestock inverter.Just an idea.KSNeptune
Sub-Vibe-R
Re: Device Under Driver's Seat (KSNeptune)
quote:And if you think the AC outlet doesn't have enough power for certain devices you want to use, there are other inverters with more power. You could replace thestock inverter.Just an idea.KSNeptune But don't forgot to change the fuse, and do not chage the converter for a to big, cause if it takes too much power to run, it can burn the wiring and cause damage.
Cajun
Re: Device Under Driver's Seat (Sub-Vibe-R)
Post by Cajun »
Thanks for the information. That sure is a big chumk of stuff to only give 100 watts of power. i have yet to find anything that consumes that low a current other than a 100 watt light bulb and I am not so sure about it.
Lorin
Post by Lorin »
I installed a 450 Watt converter in my conversion van - enough juice to power the nintendo and game cube....the TV and VCR are 12 volt. Personally, I don't like the idea of too much 110 VAC running around from a safety point of view.
Lorin2003 Pontiac Vibe GT, Neptune-mono, moons & tunes, power package, side impact airbags, rear seat covers, bumper protector, cargo mat.Mods installed: TRD exhaust, TRD stb, Mods removed: TRD CAI - annoyed by CEL
