Where are my six speakers?
fennrysha
Post by fennrysha »
I just got a Vibe with the Moons and Tunes package.It's supposed to have six speakers but I can only find 4.Can anyone tell me where all six are?Thanks.
`03 Vibe AWD ShadowMoons & TunesPower Package
NY Pete
Re: Where are my six speakers? (fennrysha)
Post by NY Pete »
tweeters in sail panels =2speakers in front doors =2speakers in rear doors =2viola, 6 speakers!
'02 Jetta 1.8T Silver Arrow/Black Leathuh - Neuspeed turbo inlet pipe, 17" VW Exor wheels, euro Bora tails, Neuspeed Sofsport Springs, Bilstein HD's, Da'lan hitch'03 20thAE GTI #3494 Imola Yellow/Black Recaros - Omori/AWE boost gauge, HPA Motorsports Short shifter, Neuspeed 28mm rear sway, REVO programming, Neuspeed turbo inlet pipe, FK Badgeless grille, Kamei eyelids and one big fat grin
fennrysha
Re: Where are my six speakers? (NY Pete)
Post by fennrysha »
Ahhh.Tweeters.Thank you.
baltimore17
Re: Where are my six speakers? (silverawd26)
Post by baltimore17 »
quote:yeah, they really dont count as speakers, but gm says they are. What, exactly, about the tweeters makes them not count as speakers? Subwoofers are speakers. Woofers are speakers. Mid range drivers are speakers. Tweeters are speakers. Flat panel electrostatic drivers are speakers. Piezoelectric transducers with an appropriate sounding membrane are speakers.You can be assured that every ten speaker sound system in a Lexus counts at least four tweeters.
NSimkins
Global Moderator
Post by NSimkins »
quote:Tell me what tweeters actually do and how they work as a speaker and then you got me.dictionary.com:quote:tweetern. [University of Waterloo] Syn. perf, chad (sense1). This term (like woofer) has been in use at Waterloo since1972 but is elsewhere unknown. In audio jargon, the word refers tothe treble speaker(s) on a hi-fi.quote:tweet·er ( P ) (twtr)n. A small loudspeaker designed to reproduce high-pitched sounds in a high-fidelity audio system.quote:tweetern : a loudspeaker that reproduces higher audio frequency soundshttp://www.sfu.ca/sonic-studio/handbook/Tweeter.html
NSimkins
Global Moderator
Post by NSimkins »
quote:But what does a regular speaker do? I mean, there is different types of speakers for different frequencies?This could start a whole new thread.... There are many different types of speakers. Woofers (Subwoofers) produce the low frequencies (bass for example). Midrange do just that; midrange frequencies. Tweeters, high frequencies. There are also "all-purpose" speakers which try to give you the best of both worlds, but you will see in many home theater systems, all 3 types of speakers are built into one unit. You get much better sound when you have specialized speakers for each frequency range.baltimore17 also is accurate...quote:Subwoofers are speakers. Woofers are speakers. Mid range drivers are speakers. Tweeters are speakers. Flat panel electrostatic drivers are speakers. Piezoelectric transducers with an appropriate sounding membrane are speakers.
baltimore17
Just to give you some real jargon, the mid range drivers used to be called squawkers, like back in the '50s and early '60s. I just recalled that one from somewhere in the depth of wasted neurons.
