excess whell spin and car front hops....
Supercharger, turbo, nitrous, and anything that has to do with forced induction
robdog
Post by robdog »
Since I put on my AEM short ram I have felt a dramatic increase in power especially when in the lift RPM range. The tires even break loose but not all the way and they kind of skip and make the front end fell like it is shaking, I know it is the tires spinning, but is it just because they are not totally burning out??? just a little spin. ps, i can't believe how much louder and more power an intake gives you.
03, Abyss monotone GT, 6 disk changer, moon and tunes, Cargo mat/nets, power package, side airbags, AEM Short Ram Intake, Borla exhaust , 35% tint all around, F1 strut tower brace, debadged, 17" Excel rims w/ federal ss595 tires.
Yoda
Re: excess whell spin and car front hops.... (robdog)
Post by Yoda »
don't know if this helps - mine does this and I haven't done CAI yet. I wonder if stiffer bushings or lower (higher rate) springs would help. Anyone with these mods?Previous thread:http://forums.genvibe.com/zerothread?id=1684
My old Abyss GT - Power, Moon and Tunes, Monochrome Mods - Installed , then removed, Sylvannia Silverstars (Headlamp only)Future mods - ?
Lancer
Post by Lancer »
I had the same thing, then I got some much better wheels and tires (Nitto 555's) that put the extra torque to better use. But it doesn't pay to put them on in the winter. Use this time to save up for some better tires so you'll be ready to rip up the road in the summer.
andrewmva
Re: excess whell spin and car front hops.... (silverawd26)
Post by andrewmva »
it's called "wheel hop" most cars suffer from this.... it is normal...post this in the suspension sectionand you might get a clearer answer and/or solutions to the problem..this has nothing to do with forced induction.
Triton
Post by Triton »
I get it here as well. I think it is normal. Light car and some pretty good power. The answer is probably to have more passengers in the car! LOL!
coratz
Post by coratz »
i find that if i rev to 3000 and dump the clutch i can peel out with zero wheel hop, if i dump at 4000 i get tons of wheel hop and shaking
Cubanpete
Re: excess whell spin and car front hops.... (Yoda)
Post by Cubanpete »
same here....no mods..........I think it has to do how I release the clutch!
Yoda
Re: excess whell spin and car front hops.... (Cubanpete)
Post by Yoda »
The problem is - if I launch at 3000 rpm, I get BOG. I think I will need to invest in stickier tires and then try to launch at 5000 rpm...
MJN2
Post by MJN2 »
Wheelhop, as defined by caranddriver.com:An undesirable suspension characteristic in which a wheel (or several) moves up and down so violently that it actually leaves the ground. Wheel hop can be caused by many problems, including excessive unsprung weight, insufficient shock damping, or poor torsional axle control. I fixed the wheel hop problem I had in my last car by replacing the original engine mount inserts and suspension bushings with polyurethane bushings.
Two-tone Neptune GT w/17" OEM rims, Nav System, BOMZ short ram, Sabresport STB
coratz
Re: excess whell spin and car front hops.... (MJN2)
Post by coratz »
i put urethane mount inserts in my old sunfire. i did not like it at all when sitting at a stoplight, the hole car shook like a pan of jiffy pop! but, it did get rid of the wheel hop and alloed me to kill my cv joints!!i do find though i get more wheel hop in the winter time when the tires are colder?????????? you would think sticky tires would hop more????
MJN2
Post by MJN2 »
True...but my Vibe was doing it in the summer too Probably the Dunlops on my car causing a lot of it though. Sticky on dry pavement (suck in all other conditions lol)
andrewmva
Post by andrewmva »
always happens...hot, cold does not matter... my guess is that when it is cold that it happens more often due to poor traction...
