springs on 18's???
travis1043
springs on 18's???
Post by travis1043 »
i have been reading a lot and there are very few people with 18" wheels. i have found some that i really like. i am trying to find the best spings for the money and wondering how much of a drop i should go with?
BlueCrush
Re: springs on 18's??? (travis1043)
Post by BlueCrush »
I have Hotchkis springs w/18's and 25/40/18 tires on my AWD Vibe. Hotchkis states it will give 1.5" front drop and 1.125" rear drop. Mine is AWD w/independent rear suspension so mine dropped about 2" front and 2" rear:Eibach Springs states 1.25" drop front and rear but I believe others have stated the actual drop ends up being about 1.5" to 1.75".Here are Hotchkis springs on eBay: http://cgi.ebay.com/ebaymotors...ZWDVWHere are Eibach Springs on eBay: http://cgi.ebay.com/ebaymotors...ZWDVW
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
travis1043
your drop looks good thanks for the advice
travis1043
Re: springs on 18's??? (BlueCrush)
ok you got hotchkis after my reading i thought about tien s??? any thoughts....
BlueCrush
Post by BlueCrush »
I don't know anything about teins. They were not an option for my car.Others here have teins and will let you know about those. Also try using the search feature here: http://forums.genvibe.com/zerosearchJust type in "springs" and you will find a ton of info on springs.
My Fleet:
travis1043
thanks blue crush... i have the gm sport package.. will that make a big difference
damronjr
Re: (travis1043)
Post by damronjr »
Quote, originally posted by travis1043 »thanks blue crush... i have the gm sport package.. will that make a big differenceYou probably won't get enough of a drop out of any of the available spring kits to really worry about the body kit, but yo may have to be careful when you first install them and make sure you have enough clearance for dips and bumps.
scherry2
Post by scherry2 »
Quote, originally posted by travis1043 »ok you got hotchkis after my reading i thought about tien s??? any thoughts....I have Tien s type I have a 2.5 inch drop front and rear. but I only have 16" rims
travis1043
looks good luv the bra
Psychobroker
Re: (travis1043)
Post by Psychobroker »
I also have Hotchkis springs & 18" wheels (Falken Circuit Specs):
travis1043
how's the ride and handling
Psychobroker
Re: (travis1043)
Quote, originally posted by travis1043 »how's the ride and handlingHandling is great -- very little to no body roll (the Progress RSB helps a lot too). Ride is firm, but comfortable. I've ridden on stiffer springs (Neuspeed in my old Corrado), and the Hotchkis seem to provide a good mix of handling and ride quality.
travis1043
thanks for the reply you helped me make my mind up
Psychobroker
No problem
