anyone tried E85?
travis1043
anyone tried E85?
Post by travis1043 »
just wondering about this ethanol gas.... has anyone used it in a vibe? it's supposed to be 105 octane
Kari
Re: anyone tried E85? (travis1043)
Post by Kari »
According to the E85 web site (http://www.e85fuel.com/e85101/faqs/ff_vehicles.php) only certain vehicles can run this fuel, and the Vibe is not one of them, so I'm not too sure I'd try it...
GenVibe Global Moderator
redlava
Re: anyone tried E85? (Kari)
Post by redlava »
I believe right now only certain government vechicles and some buses are running E85. Iowa has Ethanol blended fuel, but it is only about 10% I believe.
millster
Post by millster »
A word of advice would be, don't.That blend of ethanol would eat the seals of your engine to pieces unless it's designed to withstand it (the Vibe is not).That, of course, is assuming it would run on it at all. It takes a lot of heat to ignite that strength of ethanol. Kari posted a good link. I would check that out.
-Millster-
2006 Toyota Matrix XR
1995 Saab 9000CSE 2.3T
1986 Jaguar XJ6 Vanden Plas (GM Drivetrain Conversion)
2007 Outback XT EJ257 2.6L Build
NUBlackshirts
Post by NUBlackshirts »
I believe that, if your car is designed to run this stuff, there is a sticker somewhere (fuel door?) that says you can use it. It will also say so in your owner's manual. The Vibe is not designed to use E85.
'04 Frosty GT <---Click here!Tein S-Tech springs; Tokico HP struts;Progress rear sway bar; DC Sports strut tower bar;Scion TC wheels; K&N Typhoon intake;GG Racing ground wires; JAW voltage stabilizer;FilterMAG SS-250; Militec-1; Sirius Satellite Radio
zionzr2
Post by zionzr2 »
there are lots of places in the midwest and elsewhere that sell the 10% Blend which is Fine!!!The newer Far less common is the E85 unless you see a bunch of lables on your car that say e-85 compliant, DO NOT put this in your vibe...Once again:10% stuff: NO PROBLEM!!E-85 stuff: BAD IDEA!!
bud_one
Re: (zionzr2)
Post by bud_one »
GMC Yukons and Chevy Suburbans/Tahoes with the 5.3 liter "Z" motor are E85compatible...that's the only ones I know of.....
millster
Re: (bud_one)
Post by millster »
A number of Ford V6's are also flexible-fuel. Unless I'm mistaken, Chrysler also has some FFV cars.
-Millster-
northvibe
Post by northvibe »
when i was looking at getting a new car i checked out the ford ffi engine to see what mpg it got with e85, its under 20 for both highway and city, not worth it unless its under a dollar a gallon i think
redlava
Re: (northvibe)
Post by redlava »
Ethanol will actually decrease your fuel economy by 5% to 10% I think I read somewhere. But it is a cleaner burning fuel and we also use less "dead dinosaur goo" to fuel our cars. So it is a trade off.
sloth
Re: (redlava)
Post by sloth »
I read a report on yahoo 2 weeks ago that said it takes more fossil fuels to refine ethanol than you get out of ethanol. I imagine they mean coal from electric plants and such. But basically it says we're wasting more resources by using ethanol than not.I don't know how credible the people that came up with the report are, could be oil people that came up with the report.
redlava
Re: (sloth)
Post by redlava »
I read a similar article in the local paper. That report was using a lot of old figures (2-3 years old) and some advancements have been made since then. But that is probably a reasonably accurate statement. Ethanol is not a fix all cure, but with more time and better technology it could be part of the solution to the worlds energy needs. The machinery that produces it could conceivable run off solar or wind power. The real problem with Ethanol is that farmers can't possibly grow enough corn to feed the world AND produce enough Ethanol to make a significant impact in the global fuel market. Just not enough farmland to do both.
GMJAP
Re: (redlava)
Post by GMJAP »
Interesting article on Ethanol and other crop fuels:http://www.signonsandiego.com/....html
travis1043
thanks to everyone who posted
