Is there a TSB for cat?
billy
Post by billy »
Saw it on a post and I'm wondering if there truly was a TSB for a recall to replace the CAT on the 04 Vibe's.
Re: Is there a TSB for cat? (billy)
Absolutely. Go here: http://forums.genvibe.com/zero...age=5Scroll down to the post from tnpartsguy, it's quite lengthy. (thanks for the info!) Or, here, it shall be copied and pasted. Not sure if this applies to Canadian models however.Quote, originally posted by tnpartsguy »Sulfur (Rotten Egg) Smell Coming from Exhaust (Replace PCM and Catalytic Converter) #04-06-05-011A - (Mar 17, 2005)2003-2005 Pontiac Vibe (Automatic Transmission Only)The bulletin was being revised to add the 2005 model year and update the Correction and Parts Information sections.Correction OPPS I was wrong!! '05 only get a CAT, not a PCM.PCM replacement is NOT necessary for 2005 model year vehicles. The PCM on 2005 Vibes already has the correct calibration.GM Will replace the PCM (2003 and 2004 vehicles ONLY) and catalytic converter with new ones. The new PCM will come pre-programmed from GMSPO.Important: Don't allow them to replace the oxygen sensors or air/fuel ratio sensors. Replacement of the oxygen sensors or air/fuel ratio sensors will not reduce the odor.Parts InformationPCM Model YearTransmissionDescriptionPart NumberQuantity2003AutomaticPCM - All Wheel Drive (SM)889741321PCM - Front Wheel Drive (SL)8897413312004AutomaticPCM - All Wheel Drive (SM)889741001PCM - Front Wheel Drive (SL)889741011Catalytic Converter Model YearsDescriptionPart NumberQuantity2003-2005Converter, Catalytic -- All Wheel Drive (SM)8897421412003-2004Converter, Catalytic -- Front Wheel Drive (SL)8897421312005Catalytic Converter - Front Wheel Drive (SL)889744011
