do you turn off your a/c when starting your Vibe ?
vibebob
Post by vibebob »
out of habbit, I always turn off the a/c when starting my Vibe .. something about making less stress on the system and then turn it on once the engine starts. or does it really make that much of a difference ?peace out,bob
no longer a vibe owner"Peace cannot be kept by force. It can only be achieved by understanding." Albert Einstein.
BlueCrush
Re: do you turn off your a/c when starting your Vibe ? (vibebob)
Post by BlueCrush »
I leave mine on. It doesn't kick in until about 3-5 seconds after it has started.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
zionzr2
Post by zionzr2 »
i usually have it off when i start....I also try and remeber to have the radio off too....rarley do though
dogboy99
Re: (zionzr2)
Post by dogboy99 »
off by habit
Ponyota
Post by Ponyota »
I don't pay much attention actually.
Click on signature to view Ponyota on cardomain
ZubenElGenubi
Re: do you turn off your a/c when starting your Vibe ? (Ponyota)
Post by ZubenElGenubi »
Off by habit as well.
I like driving with the windows and moonroof open, so I don't use the AC much, but if I do use it I try to turn it off a little before I shut off the car, and as a result it's never on when I go to start the car
I don't bother with turning anything off... I would hope that the compressor wasn't designed to run when cranking the engine. At least that's logical. And from an electrical perspective, the car will cut the power to quite a bit of electrical equipment when cranking as well, so I don't worry about an excessive electrical load when trying to start the thing up...
Image Image
esjones
Re: do you turn off your a/c when starting your Vibe ? (ColonelPanic)
Post by esjones »
Quote, originally posted by ColonelPanic »I don't bother with turning anything off... I would hope that the compressor wasn't designed to run when cranking the engine. At least that's logical. And from an electrical perspective, the car will cut the power to quite a bit of electrical equipment when cranking as well, so I don't worry about an excessive electrical load when trying to start the thing up... Colonel, I think you have the essence of this issue. When the car is cranking, the electrical system already cuts the radio, the HVAC blower, and other accessories. I don't know for certain if the A/C compressor clutch is disabled during cranking, but I would think that would be the FIRST thing that the electrical system designers would want to shut off!If anyone has time on his/her hands, it should be easy to have one person watch the compressor while another person starts the car.
- Earl Earl Jones, Sales and MarketingHorizon Systems LLChttp://www.horizonsystems.com/ Skype ID: esjonesMy Vibe: '03 Base, 5-speed, ABS, Alum. Wheels, Power Pkg, DVD Nav., Security, Neptune/Graphite
Raven
Re: do you turn off your a/c when starting your Vibe ? (esjones)
Post by Raven »
From what I hear, it's a good idea to turn off the A/C a minute or so before turning off the car to allow water to drain from the condensor. This reduces the musty smell sometimes associated with A/C caused by stagnant water sitting in there growing fabulous ecological micro-systems. I sometimes remember to do this but usually not.
esjones
Re: do you turn off your a/c when starting your Vibe ? (Sunny)
Post by esjones »
Quote, originally posted by Sunny »From what I hear, it's a good idea to turn off the A/C a minute or so before turning off the car to allow water to drain from the condensor. That makes sense. If I think about it when driving home, I'll switch off the A/C as I turn onto my street, so the last of the condensate drains out onto the street instead of onto my garage floor.
mikey00
Post by mikey00 »
You have to leave it on, if you have a remote starter and want to cool the car before entering.
Oh yeah, if you turn the A/C off and keep the fan running for a while before arriving at your destination, that does work wonders for the A/C system. Tis good to get as much water out of there as possible, otherwise things will start growing and funk shall ooze from the vents. It's really nasty.. I used to do that to my Vibe, but kinda forgot about it. It smells pretty nasty, either someone took a leak down into the cowl vents or I've got some serious funk growing inside the dash.
Image Image
dsegundo
Post by dsegundo »
like those people that sit there for 5 minutes before driving....?????Cars today are just so much more advanced...
Desi SegundoFlint, Michigan'04 All Silver Vibe GT (Valerie) w/ the Sport packageSony CDX-M850MP H/U, Infinity CS6000 components, Rockford Fosgate FFC65, driven by Alpine MRP-F240 and Alpine MRV-T707 rocking 2 10" Alumapro'shttp://www.classicappreciation.com
ArcsVibe
Post by ArcsVibe »
Quote, originally posted by esjones »That makes sense. If I think about it when driving home, I'll switch off the A/C as I turn onto my street, so the last of the condensate drains out onto the street instead of onto my garage floor.That is what I do, a few minutes before I arrive at my destination.
Genvibe Global Moderator
MOTM September 06 & July 09
VOTM April 06
Matrix XR 2010 (5-09-2014)
vibebob
Post by vibebob »
the Col has it... "Oh yeah, if you turn the A/C off and keep the fan running for a while before arriving at your destination, that does work wonders for the A/C system. Tis good to get as much water out of there as possible, otherwise things will start growing and funk shall ooze from the vents. It's really nasty.. "when I had my VW on it's forum they suggested just that, turn off the A/C but leave the blowers on and it'll really help with the funk smell that can be generated.I've also heard that if you get the funk, to turn on the A/C and spray some Lysol into the vent and that'll help with removing the bacteria causing the funky smell.
