can anybody read this or make this bigger i cant read it. can you tell me the side scales span and increments
here's a version with the hopefully easier to read numbers on it, I didn't add all the numbers, but enough to show what the incremements are.Y axis (Left) is "Torque Flywheel" Y axis (right) is "Power"X Axis is "Eng rpm"lokks like Folder could be "Turner 03 vibe"Run ID looks like "camcan fuel" or "camcon fuel" or maybe "cannon fuel" So mr turner, what are doing having monkeywrench racing run cannon fuel in your vibe?
Blue line is torque, and it's scale is on the left.Green line is Hp, and it's scale is on the right.I enlarged it a little, but it still is difficult to read.
thank you. this was my first camcon dyno. i will have more with more tuning shortly. it says flywheel but its wheel power. still the baselines are kinda low for a 5 speed.
