I got just what you need brotha.I swear by these puppies. They're called Scotch Reclosable Fasteners (Dual Lock). I got them at Target, Staples, can't remember, one of those two. They're the same premise as velcro, but instead of the "fibers" velcro is made from, they're plastic. They hold REAL strong, and should not be a problem for your mats. You might want to consider gluing the strips to the back of the carpet, but the adhesive on them already should grip the plastic of the seatbacks tightly on their own. They come 2 pairs to a package, I'd say for security, use 5 pairs on the 60% seatback (one in each corner plus a third one in the middle of the top part for extra hold), just 4 pairs on the 40% seatback should do it.They sell two kinds of this stuff though, make sure you get the one that's 1 inch by 3 inches. They sell stuff that's like 1/4" wide, that stuff will never be strong enough for this kind of application.The package says the adhesive is permanant, btw, but it will peel off whenever you decide you want to remove it from the seatbacks. You might need a bit of adhesive remover to get residue off, but they're very much not permanant.Any questions, lemme know.EDIT: Here's the data sheet on 3M's site too, if it helps you locate them.
http://products3.3m.com/catalo...print
2009 PONTIAC G8
