Bad news.....
Supercharger, turbo, nitrous, and anything that has to do with forced induction
andrewmva
Bad news.....
Post by andrewmva »
Threw a rod Sat night on our 1zz project SO today I ordered a new block, rods and bearings. we were running on the highway and the boost spiked really high really fast and that was it. Threw the rod straight through the block. We are paying for the new block, rods everything. I'm just disappointed. There are a few weak spots that we need to address, and the fact that it is mid engine car brings other complications to the table. Mid engine cars tend to have insufficient oiling systems. under heavy accel the oil gets stuck in the pan and is not circulated properly which may have also contributed to losing the engine. - I will keep everyone posted on the progress from here. For now I'm sulking..... and I'm really pissed off.
d_m_kolb
Re: Bad news..... (andrewmva)
Post by d_m_kolb »
Come on man if you used Amsoil you wouldn't have a oil problem. Sorry you know I'm kidding. I'm sorry to hear about the engine. Were you doing some high RPM runs when this happened? What caused the PSI increase?This is kinda off topic but what have you done to the engine in your Matrix?
MadBill
Post by MadBill »
Bummer! But as one of GM's early leaders said: "The price of progress is trouble." Also, Harold Bettes of SuperFlow:" If a racer is head and shoulders above the others, chances are it's because he's standing on a pile of broken parts."When the engine's apart, I'd be interested if a piston broke first, leaving the rod flailing around, or if the rod just folded under the boost.
Faultline
Post by Faultline »
All I have to say ....is that you must have been a Raiders fan
pics 10/2/05 http://photobucket.com/albums/a386/Faultline05/2003 Base Vibe, frosty color,moon n' tunes packagemods: Eibach sportline lowering springs,17"centerline forged wheels -silver excels -Goodyear Eagle F1 tires 225/50/17's-ACT HD clutch,2.5" exhaust,ES motormount inserts,up graded to 6 spd transmissionStafford Fabrication turbo kit: Garrett T3 turbo, FMIC ,SF BOV. ,Alcohol/water injection,and SF centerfeed fuel rail
slbpsi63
Re: Bad news..... (fault line)
Post by slbpsi63 »
quote:All I have to say ....is that you must have been a Raiders fan He didn't say her burned his car or looted his own city!!!! LOL RAIDER FANS ARE THE WORST (with the exception of MYKIDSGT, very classy in our conversations)
Base Vibe, Shadow Monotone, 5sp.
NovaResource
Post by NovaResource »
That sucks but you know what they say in racing: "If you don't break anything, you aren't trying hard enough."About the oiling system: looks like it's time for a dry-sump.
DABEAR95
Post by DABEAR95 »
Ouch, to what do you attribute the spike in the boost?Jason
2003 Vibe GT Lava w/accent + 17'' wheels2002 VW Golf TDI 43City/52Highway lifetime1995 Camaro Z28 CAI,!TB,Airfoil,Shorty Headers,!CAT,Borla exhaust, 3.73's w/eaton posi. 13.5@105 with 245/50/16 Michelin XGT's = no traction
NY Pete
Post by NY Pete »
hey guy... there's a whole motor on ebay... cheap! http://cgi.ebay.com/ebaymotors/ws/eBayI ... gory=33615 maybe that'll help...
'02 Jetta 1.8T Silver Arrow/Black Leathuh - Neuspeed turbo inlet pipe, 17" VW Exor wheels, euro Bora tails, Neuspeed Sofsport Springs, Bilstein HD's, Da'lan hitch'03 20thAE GTI #3494 Imola Yellow/Black Recaros - Omori/AWE boost gauge, HPA Motorsports Short shifter, Neuspeed 28mm rear sway, REVO programming, Neuspeed turbo inlet pipe, FK Badgeless grille, Kamei eyelids and one big fat grin
andrewmva
Re: Bad news..... (NY Pete)
Post by andrewmva »
here are some pics of the nightmare.... thease are pictires that I am not proud of, -but I feel obligated to show, it happens, it happened to us, I'm not going to hide anything -but I'm not going to let it happen again!!! ---Andrew
andrewmva
Re: Bad news..... (DABEAR95)
Post by andrewmva »
quote:Ouch, to what do you attribute the spike in the boost?Jason not sure, possibly a vac line.
NY Pete
Post by NY Pete »
OOF! Any idea what peak boost was before the bottom end gave out? And was the failure entirely borne by the bottom end (i.e. was there enough pre-detonation with that kind of cylinder pressure to damage the valves/head?)...?Again, we feel your pain...
andrewmva
Post by andrewmva »
quote:OOF! Any idea what peak boost was before the bottom end gave out? And was the failure entirely borne by the bottom end (i.e. was there enough pre-detonation with that kind of cylinder pressure to damage the valves/head?)...?Again, we feel your pain...No Idea on the peak boost... I have to hook up the laptop and check, -but I dunno if they were dataloging or not. The damage was the bottom end ONLY.... no detonation -but like I said I was not there, I have afeeling there was just too much power for the rods to handle.
andrewmva
Re: Bad news..... (Admin II)
Post by andrewmva »
quote:Come on man if you used Amsoil you wouldn't have a oil problem. This is kinda off topic but what have you done to the engine in your Matrix? I use AMSOIL in EVERYTHING!!!!! love that stuff!!! My car is stock but I have a few goodies in mind
cohocarl
Post by cohocarl »
quote:here are some pics of the nightmare....Wow.
andrewmva
Re: Bad news..... (cohocarl)
Post by andrewmva »
solution to our rod problems... and some lubication tricks
coratz
Post by coratz »
makes me wonder when you hit lift, did the rod go? i heard through a buudy that there is a surge in oil preasure to activte the diff lobe? probaly why the gt motor had a much larger oil capicty. im not even sure if you had the gt motor. what if there was even an aftermarket larger oil pan?
coratz
Re: Bad news..... (coratz)
Post by coratz »
id be very intereted in seeing the hook up the turbo, when is was working
MYKIDSGT
Post by MYKIDSGT »
quote:--------------------------------------------------------------------------------All I have to say ....is that you must have been a Raiders fan --------------------------------------------------------------------------------He didn't say her burned his car or looted his own city!!!! LOL RAIDER FANS ARE THE WORST (with the exception of MYKIDSGT, very classy in our conversations) _______********************************************************Thanks for the nice words slbpsi63.Andrew, sorry to hear about what happend. I know I am a little behind.Look forward to your Good News in the future.
MYKIDSGT VIBE GT ABYSS POWER/MOON & TUNES19" MILLE MIGLIA RIMS MICHELIN PILOT SPORT # 225/40ZRPics are Here http://members.cardomain.com/mykidsgt
PBFlash
Re: Bad news..... (MYKIDSGT)
Post by PBFlash »
quote:makes me wonder when you hit lift, did the rod go?This was on a 1ZZ so there is no lift.
Satellite Vibe GTMoons and Tunes Package with 6-Disc In Dash CD, Safety/Security/Power Packages, cargo mat. 35% tint all around (except windshield)18 in Motegi Racing MR8 Wheels/Nitto NT 555 225/40ZR-18 tiresStainless Steel Exhaust TipInjen CAIPics of my Vibe CarDomain.com
Chris
Re: Bad news..... (PBFlash)
Post by Chris »
Bummer about the engine! Thanks however, for showing us the damage.On a lighter note... one of the porche teams racing in the LeMans 24 hour was heard to say that they had to drop out due to electrical problems... that is electrical problems that occurred when a piston exited the block and severed some wires
Chris Car: Base Abyss Vibe 5 spd + Mags & Power Pkg - no modsBike: Suzuki GSXR1100 4xK&N's V&H pipe and headers
Mr. Poopypants
Post by Mr. Poopypants »
quote:Come on man if you used Amsoil you wouldn't have a oil problem. Shameless plug, ha, I love it.
