Quote, originally posted by binary »Grab them here:Audio22.4MBFlash 1.5MBThanks for the effort binary, but I couldn't get the Audio .zip to work (said it was corrupt) and the Flash .zip was not found on your server.I went ahead and uploaded the entire CD using a maximum compression .zip file. It can be downloaded here:
http://www.genvibe.com/html/misc/vibecd.zip [33.1 MB, sorry ]Depending on your UnZipping software (for Windows, I use WinZip (it's free)), make sure you extract the files using the original folder names so the files are placed in the proper directory structure in the extraction folder you choose.For WinZip, I've attached an image below that shows the option that needs to be checked to be sure the folder structure is kept intact during extraction. This option is usually enabled in WinZip by default anyway.I've tested this on Windows-based PC's at this time and the .zip file appears to work fine. After extraction, just run the VIBE.EXE program at the root of the directory and it should be good.
