I've mentioned this memo before and thought you might want too read it. It's been in effect for over a year. SERVICE - ALL BUICK, CADILLAC, CHEVROLET, GMC TRUCK, ISUZU, OLDSMOBILE, PONTIAC AND HUMMER DEALERSSubject: A/T Shift, Engine Driveability Concerns or SES Light On as a Result of the Installation of an Aftermarket Reusable, Excessively Oiled Air Filter -- 2004 and Prior Cars and Lt Duty Trucks and 2003-2004 HUMMER H2Message #: VSS20040056Corporate Bulletin Number 04-07-30-013 will be available in SI on March 18, 2004.Automatic Transmission Shift, Engine Driveability Concerns or Service Engine Soon (SES)Light On as a Result of the Installation of an Aftermarket Reusable, Excessively Oiled Air FilterModels: 2004 and All Prior Cars and Light Duty Trucks2003-2004 HUMMER H2DO THISFirst, Inspect the vehicle for a reusable aftermarket excessively oiled air filterDON'T DO THISDO NOT repair under warranty if concerns result from the use of a reusable aftermarket oiled air filter.The installation of an aftermarket reusable, oiled air filter may result in:1. Service Engine Soon (SES) Light On2. Transmission shift concerns, slipping and damaged clutch(es) or band(s)3. Engine driveability concerns, poor acceleration from a stop, limited engine RPM rangeThe oil that is used on these air filter elements may be transferred onto the Mass Air Flow (MAF) sensor causing contamination of the sensor. As a result, the Grams per Second (GPS) signal from the MAF may be low and any or all of the concerns listed above may occur.When servicing a vehicle with any of these concerns, be sure to check for the presence of an aftermarket reusable, excessively oiled air filter. The MAF, GPS reading should be compared to a like vehicle with a OEM air box and filter under the same driving conditions to verify the concern.Transmission or engine driveability concerns that are the result of the installation of an aftermarket reusable, excessively oiled air filter are not considered to be warrantable repair items. Here's K&Ns responce.
http://www.knfilters.com/warrantyletter.htm
