Clutch popping and Throttle by wire
GMJAP
Post by GMJAP »
One thing I've always liked about a manual is being able to "pop" the clutch to start it when the battery is dead.However, it just occured to me that the "drive by wire" electronic throttle in the 2005 Vibes might prevent me from being able to do that.Anyone have any idea if you can still "pop" the clutch to start a car with electronic throttle?
cohocarl
Re: Clutch popping and Throttle by wire (GMJAP)
Post by cohocarl »
I don't know. You'd have to have enough juice in the battery for the computer, spark, etc. If the battery was down enough where it wouldn't turn over, but enough for the electronics, it probably would bump start. No juice at all, then I'd say it probably wouldn't fire. Just my guess.My Vue is a 4 cyl Ecotec with a drive by wire throttle also. One thing I noticed, and I'm not sure if it's the same on the Vibe, but there is a VERY slight delay between the accelerator being pushed down to when the servo on the throttle plate responds. Hardly noticeable, but it's there. Anyone notice that on their drive by wire Vibes?
Sold 6/16/04 03 Vibe 5-speed, Hotchkis Sway Bars & Springs, Hooker Aerochamber, Panasonic Stereo, Hitch, Silverstars,04 Saturn Vue 2.2L Ecotec, 5-speed, 01 Stratus R/T Coupe 5-speed (wife's car) 85 Corvette 268 CompCam, 882 heads, FlatTops, 24lb injectors, Hooker Aerochamber true duals, 58mm TB, Holley AFPR, Siamesed intake base, Polished TPI.
GMJAP
Re: Clutch popping and Throttle by wire (cohocarl)
Post by GMJAP »
Quote, originally posted by cohocarl »My Vue is a 4 cyl Ecotec with a drive by wire throttle also. One thing I noticed, and I'm not sure if it's the same on the Vibe, but there is a VERY slight delay between the accelerator being pushed down to when the servo on the throttle plate responds. Hardly noticeable, but it's there. Anyone notice that on their drive by wire Vibes? I definitely noticed that when I first got the Vibe. Used to it now.
ragingfish
Post by ragingfish »
I don't see why you shouldn't be able to...isn't the whole thing behind the "push & pop" method just getting the crankshaft and cams turning? I dunno, I could be wrong...
2009 PONTIAC G8
