Replaced headlights 3 times..
vibechick03
Post by vibechick03 »
I've replaced my headlights 3 times in the last 4 months. The last 2 replacements have been Silverstars. Does anyone know of an electrical problem I could be having?? Short?? Or is this typical?? I drove with stock lights for 8 mos, then switched to Eurodesign blue lights, then Silverstars.... Any help would be great!
'03 Base VibeSatellite MonotoneMoons and tunesKeyless entry / electric everythingTinted windows and pin stripe (ordered from someone else)Metallic white overlays, Pearl white rims paintedNext: Magnaflow exhaust & Injen CAI Xenon blue head-light bulbs and blinkers
Re: Replaced headlights 3 times.. (vibechick03)
Anything other than standard halogens have been problematic in my car... I burned through several sets of $ilver 's and one set of Sylvania Xtravisions. One set of $ilverstars that were in the fogs even died at the exact same time - so I'm thinking I probably had a voltage spike which whacked both. Only thing I can suggest is to try a set of standard halogens, see how long they last... If those die, you probably have an electrical issue... Otherwise, just dealing with faulty bulbs, I imagine... I've had good luck since going back to plain ol' GE halogens, they've been in there for at least a year I'd say - no problems since. Not as bright or whatever as the other bulbs, but then again, a set of Silverstars isn't bright at all when they're burned out. lol!
ArcsVibe
Post by ArcsVibe »
Silverstars don't last long at all as you can see. Stick to the OEM bulbs and you won't go wrong.
Genvibe Global Moderator
MOTM September 06 & July 09
VOTM April 06
Matrix XR 2010 (5-09-2014)
drunkenmaxx
Re: Replaced headlights 3 times.. (ArcsVibe)
Post by drunkenmaxx »
ive got all my original bulbs and it's been 3+ years and 60k+ miles...
Mr. Poopypants
Post by Mr. Poopypants »
I'll beat that dead horse.......Silverstars are nice, but they burn out very fast.
drunkenmaxx
Re: Replaced headlights 3 times.. (Mr. Poopypants)
in all reality, how big of a deal is it for the light they emit to be blueish?
vibechick03
I like the blue-ish look myself, but i'd rather have them work for more than 2 months. Whats another good brand I should try that are bright blue??
AKLGT
Post by AKLGT »
the last set i purchased were from walmart for $18/pair. they were xenon blue bulbs, not sure exactly. installed them back in october??? no problems. i had NO luck w/ silverstars. replaced those every 6 mos it seemed. now the hubby has has his silverstars in his vibe for over a year without replacing them, so who knows!
AKLGT1998 Subaru 2.5RS
tnpartsguy
Post by tnpartsguy »
I'd just buy Phillips Xtra Vision Bulbs, and be VERY careful installing them, most of the time the oils on your skin is what kills a halogen bulb. I won't buy Silverstars, ect anymore, the life of the bulb is too short for the money.One other thing, make sure the electrical blade connections are tight, if they are loose, that can cause the bulbs to blow early.
vibechick03
Were do i get those?? and are they blue looking?
Mr. Poopypants
Re: Replaced headlights 3 times.. (drunkenvibe)
For me, it's not the blue look, it's the increased light output.
Rico Rose
Post by Rico Rose »
I installed Sylvania "Cool Blue" bulbs over 4 months ago (Wallmart $18/pair). Have had no problems and the increase in light candle-power is great. Not as bright as Silverstars, but I think they will last longer. I was very careful when installing them I used latex gloves (powder free)...
2006 Vanilla PT Cruiser Touring Edition.
